1973 Pinto hatchback for sale
Date: 11/13/2023 11:30 am
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 08/13/2018 02:46 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
Date: 09/06/2020 01:57 am
Date: 07/30/2020 11:45 am
Date: 03/21/2017 07:47 pm
Front Body parts needed
Date: 02/09/2018 06:09 pm
  • Online today: 1,166
  • Guests: 440
  • Total: 440
rear gears
Started by pintoman, September 14, 2004, 06:41:32 PM
71pintok
I have a 9 in rear end, it has Richmond 3:88 gears it. Goes like snot.
Henry
pintoman
  Hey 73pinto thanks for the offer,i'm still looking around here in Columbus,Ohio.Theres a chance i might find one nearby.I will keep you in mind if i can't find one.There might be one at the fall super swap that i can get cheep[yea sure].
pintoman
  The 7.5 is already to go,the gears have been set up and checked.All it needs is the axel shafts and brake backing plates.
73pinto
7.5's also came in rangers and Bronco II's with limited slip.  Also in aerostars, but not sure if they were LS or not...
Pintoman, where are you located?  I've got an 8" in a 76 bobcat wagon that I'll let go if you can come get it.  Its an open 3:00, but from what I understand its not hard to make them LS.  I'm in Dinwiddie, Va.  Let me know.
-Harry
Stock 73 2.0/4spd 3:40 maximum slip, cd player, pop-out quarter glass.  Soon to be slight performance 2.0/5spd and much more...
CHEAPRACER
Before you put your 7.5 in, pull the rear cover and remove the center diff pin and check for perfect straightness. If it's a Posi, it most likely came out of a v-8 car and I've seen more than a few 5.0's bend the pin and bust the spiders. That's why they finally went to the 8.8 (the same rear as the 1/2 ton truck).
well, there you go with the "F" word.............. ;D    FREE
pintoman
  Looks like a 7.5 is going to go in.8" rear axels are hard to find in this area.The 7.5 is free [my kind of price],i know it will fit and it will take alot of work.But in the long run it will be worth it.
Go with the 8". It will be a much better fit.
pintoman
  Need new rear end [for the pinto].The rear spider gears bit the dust.I have a 7.5 with a 3.45 posi that i can put in ,but i would rather have a 8" out back.Less trouble and a quicker fix.
