Pinto Parts for sale
Date: 06/19/2017 02:01 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 01/24/2021 07:54 pm
Date: 11/02/2019 10:25 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 05/28/2017 03:20 pm
Gas Tank Sending Unit
Date: 05/22/2018 02:17 pm
Date: 08/09/2018 11:09 am
  • Online today: 1,090
  • Guests: 957
  • Total: 957
center wheel hole
Started by dholvrsn, January 20, 2009, 12:11:02 PM
The steel wheel center hole fits snugly on the hub to help center/support the wheel.  The early model steel wheel center holes are about 2.43" ID while the later models are about 2.52" ID.  I believe the 1974 was the first year of the larger hub.  So the early steel wheels will not bolt on to the later hubs.  The after market aluminum wheels use just the lugs to center the wheel and their center holes are large enough to fit the larger hubs (at least the ones that I have owned).  Not Sure about the Ford aluminum wheels (the 73 sales brochure shows them as an option).
What is the diameter of the center hub hole of a standard Pinto wheel? Thanks!
