1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 12/31/2017 09:03 pm
Date: 11/08/2019 10:01 am
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
74 pinto
Date: 09/11/2016 06:32 pm
Early 2.0 engines
Date: 05/09/2018 12:45 pm
  • Online today: 1,972
  • Guests: 944
  • Total: 944
Compression testing w/ metric tester
Started by matt68, January 01, 2009, 08:52:26 PM
the Cologne motor uses (after 1975) a metric plug. my 2.8 has a 76 American head and a 77 German head, both use the same plug size and my Metric Compression meter works just fine in it. =) Hope this helps
matt68
Looking to test my 1977 Bobcat 171cu 2.8l V6. The only compression testers I can find are metric. (14, 16, 18mm plug sizes.)
  Does anyone know if I can use a tester like that on my Cat w/ standard plug size? I know some metric sizes come close, but will that matter?
