Clutch Cable Needed
Date: 04/03/2017 11:03 pm
Crane Cam
Date: 02/26/2018 07:50 am
Date: 01/28/2021 03:49 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
Date: 10/15/2017 10:03 am
v8 springs
Date: 05/07/2017 04:46 pm
Date: 01/21/2023 04:19 pm
Date: 10/24/2018 07:35 am
Date: 08/13/2017 02:01 pm
  • Online today: 1,972
  • Guests: 1019
  • Total: 1019
Turbo Pinto Update #2
Started by Wittsend, December 07, 2008, 09:52:47 PM
turbo74pinto
i havent had any issues.  it seems to work fine for me.  keep in mind that i have a hurst shifter too.  i dont know how it would be on a stock set up.  in fact today i fired up the laptop and burned up about 3/4 a tank of gas tuning it and all the shifts felt fine.  although, i did notice all that vibration.  kind of annoying but in a car with no insulation, no silencer ring, and no muffler....theres alot of annoying stuff going on.
bob
Bob,
  Thanks for the pictures.  I remember you saying you did away with the rubber.  Initially I was baffled as to how you could get so much angle.  But, with the bolt only it makes a lot of sense.
That said, initially I bent the shifter and the less than vertical angle (similar to yours) made getting into gear very difficult.  With the spacing plate I'm using it is  MUCH easier.  Does your shifter angle cause issues?
Tom
turbo74pinto
yeah, for a cruiser that should do fine then.  i got these pics for you anyhow.  yes, those fillers are welded in place.  but just tack welds.
bob
http://s307.photobucket.com/albums/nn294/ford371/?action=view&current=PC100001.jpg
http://s307.photobucket.com/albums/nn294/ford371/?action=view&current=PC100002.jpg
Doug,
  The eye to eye (center to center) distance is 3-5/8."
To give you specifics on the"feel" I need to describe the elements.  I'm, 6'0." Currently I have the stock seat on the second to last notch (moving rearwards).  I also replaced the stock Pinto steering column with the T/C column.  Where that puts the steering wheel in relation to stock I'm not exactly sure.  I'd say it is pretty close to stock.
  Last night I bent the bend near the threaded part to move the knob rearward. At best it probably moved 1", if even that.  I also cut about 1/2" off the threads and ground the inside of the T/C shift lever to lower the knob.
For me 1st gear is 5" forward of the steering wheel. 2nd gear is about 1" forward of the steering wheel.  While not uncomfortable, I would prefer the shift lever back about two inches more. I'd also like it about 1-1/2" lower.
That said, I really can't move it back any more.  As it is, the extender is hitting the rubber boot seal.  Should I extend it more there could be clearance issues and damage to the boot.
So, to put it all in perspective, the shifter seems a little too high and a little too far forward in 1st gear.  2nd gear is close to where I would expect to find neutral.  We don't live in a perfect world and what I have is more than doable for me.  Whatever deviates from "ideal" is certainly acceptable.
Hey, for free and about 20 minutes of my time it is a vast improvement over the stock position.
Tom
How far back does your extender measure for eye to eye? Does your hand pretty much naturally fall to the knob when it drops from the steering wheel?
You know Bob, I was concern about flexing too.  Especially when I saw how thick some of the "$tore Bought" shift extenders. are  But, that has not been my experience.
Now, my car is a "daily driver" and I'm 51.  So, I would rather do without the noise (thus retaining the rubber), and the hitting gears hard isn't where I'm at. A quick, but gentle shift and a progressive squeeze of the throttle is enough to satisfy me.
Tom
turbo74pinto
mustangs and tcs have different levers.  the tcs have a farther "swoop" towards the back of the car.  in mine, i filled the original mounting holes, drilled them offset to lean the shifter farther back...about 2 inches....and solid mounted without the rubber insulator.  that rubber is only there to reduce driveline vibrations from the shifter lever.  i dont know your plans for the car, but id think that extention will flex in hard shifting.  ill try to get some pics of the 2 different shifters tomorrow so you can compair.
bob
 An issue with the T-5 in a Pinto (and my personal size/tastes) is that the shifter is too far forward.  I cut, bent, welded the original shifter to where I "thought" it should go.  Unfortunately this created a very difficult angle for the shifter movement.  It wasn't that the knob wasn't where I wanted it, but rather the applied leverage angles were all wrong for an effective shift.  I created this plate (see pictures) and used it with what I believe is a Mustang shifter (I'm not sure if Mustang and T/C shifters are different).
  If you'll notice (second picture, top view) I let the back side of the clamp overhang as it did on the mounting stub.  I cut the metal, but not the rubber on the front side. I then folder the rubber forward to prevent metal on metal contact.
Anyway, it works great and all it cost me was my time.  Slowly but surely, one thing at a time it will get better.
Tom
