Date: 02/04/2018 08:26 am
Date: 07/04/2017 03:26 pm
Date: 07/08/2022 11:51 pm
Date: 01/24/2021 07:54 pm
SVO SWAP
Date: 03/15/2018 03:12 am
Date: 07/17/2018 09:49 pm
Date: 07/13/2018 02:21 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
  • Total Topics: 16,268
  • Online today: 153
  • Guests: 98
  • Total: 98
Dash pad removal? 1979
Started by russosborne, December 06, 2008, 01:42:34 AM
Well, I finally got it off. Whoever designed that setup is a sadist.
Just for future reference, here is the details for my car, a 1979 Hatchback standard interior, non tach, and no airconditioning, just in case things differ.
There are 6 studs with nuts. There is one above the drivers vent duct, one above the instrument cluster(roughly in middle) 2 that also hold the dash speaker, one roughly in middle of glove compartment, and one above the passenger vent duct. The wrench/socket to fit these nuts is 11/32 inch.
There are also 4 hex headed machine screws. These are towards the front of the dash(or closest to the driver/passenger). These are 1/4 inch. There is one above the driver's vent, one between the instrument cluster and the heater controls, one just a bit towards the center of the car from the glove compartment, and one above the passenger vent.
All 10 of these must be accessed from inside the dash. If you can get the vent ducts out it would be much easier, but I couldn't get both, and I may have broken the passenger side trying. The instrument cluster, heater control, and glove box have to come out. I took out the ash tray entirely also, that made it easier for me, but you may not have to.
And for those who may not know, like me until tonight, removing the dash pad does NOT give you much more access to the back of the dash. I didn't realise that almost the entire thing was closed in, with a few cut out slots. I had assumed(my bad) that it would have been like the vintage Mustangs, which when you remove the pad there is no structure left.
I hope that this might help someone down the line.
Thanks for all the answers.
The only screws that would be present if any are just beneath the front ridge of the dash pad; you should be able to see them, they are not hidden. 2-3 at the most if at all.
Bill, I have finally gotten around to doing this. It finally got warm enough to not be miserable in the garage.
I found and got the 6 nuts off of the studs, but could you give me an idea of where the screws might be? I am not having any luck finding them so far.
Thanks,
Ouch. Guess removing it to make it easier to work on installing aftermarket gauges isn't worth it.
Thanks,
Quote from: russosborne on December 06, 2008, 01:42:34 AM
I can't find any screws in this thing at all. How do I get it off?
thanks,
It has 5 or 6 studs that pass through the dash, and a couple of screws that go up from under the dash.  You need to remove the vents, ducts, gauges, glove box, and any other item in the way to gain access to the nuts and screws.
thanks,
