Looking for front seats
Date: 08/10/2021 09:54 pm
Misc pinto parts 71-73 2.0
Date: 05/05/2020 11:56 pm
Date: 01/20/2018 07:51 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Date: 02/28/2018 09:18 am
Need Interior Panels
Date: 07/09/2018 04:59 pm
Date: 12/26/2016 04:29 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
1980 Ford AM radio
Date: 12/22/2019 11:57 am
  • Online today: 125
  • Guests: 104
  • Total: 104
Lock removel?
Started by pintoches, December 03, 2008, 11:04:11 PM
Quote from: dave1987 on December 05, 2008, 11:34:54 PM
71pintoracer is quite the improviser! :D
Whatever works, right?!!  ;D  Years ago when I was dirt track racing I had 12 Pintos at one point. They were so plentiful that I could get them free or very cheap. (always under $100) But most of them had no keys, so rather than pull the wheel and disassemble and drill and hammer and all that, I would just slide hammer them out so I could turn the wheels to load them up.
pintoches
I got it out today with no harm to the column. We drove the pin in with punch then broke the crome off did some prying some more hammering and out it came. will put the new one in after church Sunday
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
Very cool! I tip my hat to you 71pintoracer!
That may be true... but he's also one of the most respected mechanics working at the local Ford dealership here.  If this is the way he says to do it, it's certainly the method I would use!
As far as I can remember, the door cyl and ign cyl have the same amount of tumblers. On later cars (mid to late 80's I think?) the first 5 cuts are for the ign and the second five are for the door. Thats prob what your locksmith is thinking about, shouldn't be an issue on your pinto. If all else fails, the easyest way to get it out is with a slide hammer.  (about a 10 pounder, borrow one from Advance or Auto Zone) Break off the chrome outermost piece, screw the slide hammer into the cyl as far as it will go, (use a long skinny sheetmetal screw) get a buddy to hold the steering wheel from the driver side, make sure the pass door is open and the glass is rolled down, (!) and bang away!! Once the cyl comes out you will have some pieces left in there that you will have to fish out. Then you can use a screwdriver to turn it to the run position so you can put the new cyl in.
Just got ahold of my locksmith and they said that on something as old as a Pinto, the door locks should have the exact same tumbler count as the ignition. He told me that he hadn't seen any car door lock that was different from an ignition until the mid to late 90s. He has been working for this company for 26 years. I would take his word for it.
See if you can find another locksmith to do the work for you.
I doubt it has more tumblers in it then the door lock. otherwise the key wouldn't truly go in all the way, at least not with a relief of some sort, so i would think they are just trying to get out of having to re-key for you. I would check with your regular locksmith and see what they say. if all else fails you can just go to a dealership with the Vin.
I ws thinking the same exact thing, but you know what, it might be. At any rate the ignition is a pain to get out without the key. When I lost the keys to mine I had to get the ignition out so I could start the car. What a pain in the butt.Yeah, the pin does have to bdo have to remove the ignition.e drilled but I think you have to drill out another part of teh lock to get it out. It's been 2.5 years since I did it so I can't tell you exactly. I just remember it taking me about an hour from start to finish, but that is also with having to break in the car since it was locked. Good luck if you  have to remove the ignition.
Does a door cylinder really have more tumblers than a ignition cylinder, though?
I will inquire about this with my regular locksmith tomorrow to find out for sure. Sounds a bit funny to me though.
They were able to make a key for mine from the door lock many years ago, If they keep telling you that try another lock smith, If anything take your Vin number down to ford they may be able to make you a key as well. but im sure that will cost upwards of 50-100$
pintoches
I called the lock smith  it was 25 dollars to have the key made. but he told me he had to have the ingnition lock too because it has more pins then the door lock.
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
are the door locks the same as the ignition? if so get a key made for the door lock then put it in the ignition and turn it to remove it.
Come to think of it, I don't think it will come out even if you drill or remove the pin. There is a "T" at the inside end of the cylinder that hooks into an eyelet on the switch shaft.
You will probably have to replace that entire section of the column with a replacement cylinder, unless someone else has any ideas.
pintoches
#4 could be a problem as i lost the key!  Any more info on the pin?
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
If I recall correctly from the two I have pulled, you have to...
1) Remove steering wheel
2) Remove turn signal assembly
3) Remove the sticker that covers the cylinder retention pin
4) Turn ignition cylinder to the run position
5) Extract the cylinder by pulling straight out
Once the cylinder is turned to the run position, the cylinder could pull straight out without any resistance.
If you are trying to remove the cylinder from a car that you drive, but the tumblers are jammed or the key has been lost, I believe that drilling out the brass retention pin might work.
I didn't know about the retention pin when I had to change the cylinder on my 78 Sedan (jammed tumblers), and i ended up destroying the column section that it mounts in. I found out about the pin after I went to the salvage yard and one of the guys showed me how to remove it properly.
pintoches
I need to change the Ing lock on my pinto.  I pulled steering wheel, took out the two screws and part of the wheel lock holder wheel lock pin still in.  what am i missing? How do i get the lock out?
72 pinto, auto floor shift
Ches Lathim
72 Pinto Wagon
78 F150 4x4
87 ford F150
