Date: 12/10/2017 01:14 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
1979 pinto
Date: 04/19/2018 02:02 am
Date: 10/03/2018 02:00 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
78 wagon instrument y
Date: 04/30/2018 07:41 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
convert to stick
Date: 05/19/2018 09:26 pm
  • Online today: 178
  • Guests: 135
  • Total: 135
Baffled!!!
Started by 77sleeper, November 30, 2008, 09:23:32 PM
You guys are spot on, I thought of that but  he said it died while just driving along and this didn't seem to be an issue with my roundy-round racers until I started turning 7000 and above. There are billit aux shafts and bronze gear set-ups to cure this problem but they are pricey. It is also helpful to fab up some shims to take out the up and down movement of the dist shaft. There is going to be a lot of junk throughout the engine, make sure to have it hot tanked, and you may want to replace the pickup tube, they can be difficult to clean and a small piece of stray metal will lock the pump...and ruin your day!  :mad:
turbo74pinto
for what its worth....the factorysetup should be non-interference.  the turbo pisto0ng are lower comp and forged.  the round tooth timing belt set ups are le3ss pron to slipping.  as as far as the turbo 2.3s....high volume oil pump+fctory dist gear set up=broken dist gear pin or sheared gear.  not all the time but it has been seen a bit before.
bob
ps, ihope my spelling isnt too bad...i cant see what im typing for whatever reason.
77sleeper
Hey dan,
i would sadly have to say you were right! well.... i guess come tax time ill just rebuild it
Bringin' Back the Pinto!
http://s222.photobucket.com/albums/dd1/77turbopinto/Pinto/
'77 Pinto Sedan
Far from stock 2.3L backed by T-5 and Ford 8" w/ gears
I think Dan is on to something. Have you pulled the distributor and inspected it yet? My guess would be the drive gear is damaged. If that's not it, check the aux. shaft.
Dan
Hi, Just wanted to throw this out and see if it's possible that the oil pump has something stuck in it and causing the oil pump drive to sheer off the roll pin on the dist gear. that would cause a timing error like your having. It did it on my 289 and i think there alike. I might be completly wrong, but, better to bring it up than nothing.Good luck on the repair. Dan.
Nothing like a 460 under the hood!!!
For some reason I remember that the dist had to be moved a lot after replacing the belt to get the timing right. In fact, I would move it back (retarded), put the belt on and then have to crank it on around (advanced) to get it to fire. If the belt was put on without doing that, the vacuum advance would hit before you could get the timing set.  The 2.3's don't seem to want to fire up with everything set at 0.
77sleeper
Today i was driving along and all of a sudden my poor pinto sputtered then back fired a few times and died. i knew what had happen because it had happened to me once before..the timing belt slipped.
my 2.3 is not turboed but im running a n/a head w/.460 lift cam on a stock turbo bottom end. not the best combo..i know, but i had to do it since i blew my other bottom end and i had the turbo bottom end sittin in the shop.
that aside.. i purchased a new belt and then lined everything up correctly and set my distributor. when i try to start it gurgles and backfires through the carb. i then checked tdc again and made sure it was on the compression stroke and checked the distributor position again. everything is set right and still nothing. i even swapped the plug wires 180 degrees to make sure i didnt set the timing on the exhaust stroke. still the same result nothin but sputtering and backfiring.
ive been told that since the turbo engines had dished pistons, the dishes were deep enough to make it a non-interference engine. and when i placed that head on the block during assembly i turned the cam slowly to see if the valves would slap the pistons and sure enough they didnt. so i dont think it's possible i bent a valve.
i'm completely baffled!!!! im no master mechanic, but if its not completely computerized i can usually figure minor and major malfunctions out. but this one has me dumb founded! maybe one or some of you might have some different ideas for me because im out!
any and all comments and suggestions are greatly appreciated!!!
Thank you,
David
'77 Pinto Sedan
