Date: 10/01/2020 02:00 pm
Wanted early pinto
Date: 10/03/2019 02:42 pm
Date: 10/14/2019 08:24 pm
Date: 08/01/2018 01:27 pm
Date: 09/19/2019 04:43 pm
Date: 02/18/2017 05:55 pm
2.3 carb intake
Date: 07/15/2020 09:25 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
  • Online today: 1,293
  • Guests: 1231
  • Total: 1231
My Black Friday Adventure
Started by dave1987, November 28, 2008, 10:01:46 PM
Quote from: dave1987 on November 28, 2008, 11:05:11 PM
lol. I was starting to worry there! Thanks Kim, I will post a shot of the pan when I get back tomorrow afternoon! :D
I thought you might get a kick out of that!!! LOL
So you are the one that made it real easy for me to get my floor pan today!!! I was wondering who would do all that work and leave that little bit to finish it off. Only took me 5 mins to cut the rest and we got out just as they closed!!! Thanks !!!!!
Ok, I was kidding!! LOL  :laugh:  Good luck tomorrow!!!!
The driver's side where my feet sit, right under the pedals, around the drain hole, has very bad rust. I put an old worn out bath towel between the floor and the carpet because it is so bad. When underneath the car, I can see some of the towel in spots!
Not only that, but that area of the floor also bows downwards since it is so thin. So it is more of a bowl than a pan right now.
No, but my pony gave me a headache lol... Is your floor badly rusted?
It all started with a trip to Sears to check out a sale they had on a cordless reciprocating saw, just what I needed to cut the floor pan out of the Bobcat at the scrapper!
So I ended up paying about $30 more than I had hoped to, but was it worth it or what?!
I took my dad with me out to the yard today since he was bored and wanted to tag along. We dropped $5.00 of gas (at $1.71/gal!!) into the Saturn and off we went.
After arriving at the yard, we signed in, paid the entrance fee and out into the Jungle we went.
After finding the poor little Cat, stripped of it's insides and feet, we started by removing the windshield. Since I had already removed the trim and fasteners in a previous visit, all was left to do was to pull the windshield. It wasn't easy though, as it really didn't want to budge. With a little work of a crow bar and a severely damaged windshield later, we managed to pry it out of it's seat and rock in all out without any glass shattering (It already had a nasty crack across it, so I didn't mind hurting it more).
Once that was done, the next step was removing the dash. Now that was the easy part. Next up was the hard part, removing the pedal and column bracket to clear out as much space as possible so we could cut the floor out without being cramped up underneath anything. About 11 - 12 bolts and nuts later, it all came out. Now the cutting begins!
We drop a blade into the saw and fire it up with a start incision through the drain hole farthest back, slicing through the sub frame and fuel lines in seconds. We then work our way around the rocker panel and up towards the firewall, running into the upper sub frame which is considerably thicker than the one we started at. We decided to stop there and go around the other way. Now going the other way, we continue to cut around the floor and along the tunnel. Once more we hit the upper sub frame and stop, thinking of how we are going to get past this large chunk of metal that stands in our path. As we attempt to cut through the top and plan to finish it off by cutting through underneath the car, the blade dulls and the saw stops cutting. I reach for another blade but there are no more! Disappointed that our efforts have gone by fruitless and the yard was closing soon, we decided to call it a day and go back tomorrow. I take the dash and we head out to civilization once again, with anticipation of the return trip to save some good floors!
So, today I was able to get myself a nice reciprocating saw with two batteries and a charger, a replacement dash which I will clean up and paint to swap out when I have my windshield work done, and some 10" metal cutting blades to finish the floor pans tomorrow.
Did anyone else get anything for their Ponies or fun tools to help aid care of them? :)
