Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
80 pinto original
Date: 08/04/2019 10:45 am
upholstery for bucket seats
Date: 10/30/2018 08:44 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 04/13/2017 04:56 am
Date: 02/08/2018 02:26 pm
Racing seats
Date: 10/24/2019 09:41 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 08/08/2018 12:26 pm
  • Online today: 1,293
  • Guests: 1204
  • Total: 1204
My Black Friday Adventure
Started by dave1987, November 28, 2008, 10:01:46 PM
Now they call it "cinders"  more traction  less melting  but it still eats cars  just not as fast. In the spring the roads are  covered in sandy/ gravel mix so for the first month or so after the snow melt   you here the pebbles  hitting  the car as  you drive  almost like  driving in a sand blaster.
I believe they use sand on the roads here in Boise, now. The roads get really nasty and dirty when the snow starts to melt.
My dad was saying they have switched from salt to magnesium phosphate, but from what I can find, MP is used as a steel treatment to aid against corrosion. I think he was thinking of magnesium chloride, which is an alternative deicer.
I will have to check with the state on this one. I will get back to you all when I find out.
Quote from: discolives78 on December 02, 2008, 10:59:14 PM
r-r-r-rust? in the floors? I'm not sure what that would be like to deal with, Dave.
Usualy in a salt  zone that = no floors Rockers, fenders,  ect....
I don't think you would like to deal with it, Chuck. With such a confined area beneath the dash, I had it real easy at the salvage yard since I had already removed 90% of the interior and the dash. When I cut out my original pan, it won't be so luxurious! I believe I will end up using my brother's air saw rather than a sawzall, since it is smaller and should be much easier to use in such a small space.
Hopefully I can get the whole welding thing down by spring. I should have my windshield and it's gasket replaced by then, possibly the headliner too!
Ladies and Gents, the spot weld bit worked pretty darn good!
The bit is very easy to use, but I highly recommend keeping a punch near by. Occasionally, the bit will start to walk away from the desired location. Hit it with a punch (preferably a spring loaded one. :)) a couple times, and go back at it. It took me about 15 minutes to drill out all of the spot welds, pry the two pieces apart with the short end of a crowbar and a hammer, and use a drift to straighten out the drain channels.
It left the floor panel looking like swiss cheese, but in the end, it should really help with welding it back into place on the sub frame, and the parallel lines of holes won't even be noticed!
Wow, they dropped since I last priced them. Can't blame you for not getting it at $30 for a used one. I am jeaulous of your floor. lol.. It's got a street sign on the driver side for now. I see what you are talkin about on removing the subframe from the new piece. Good luck on drilling out the welds. I gotta get me a spot weld bit so I could do the work  on my car a littl easier.
I was considering it, but a new dissy from Parts America is only $48 and it comes with a lifetime warranty. I was just thinking that if I would replace something that is always moving, and electrical, it's bound to go out more than once during the time I drive the car as a daily driver, I might as well just buy a new one and replace it free of charge when it goes out. The salvage yard wants $30 for a dissy.
Here is a shot from a little over a year ago of the driver's side floor. It is only slightly worse now, but still stable for the most part.
That's  some good parts finds you got there. That's cool you only needed that part of the floor. My entire floor is nothing but swiss cheese & needs MAJOR repairs. Fortunately I have the front of an old washer my dad got rid of this year. Nice find on the plug wires. You not want the distributor? It seems always a good idea to have a spare one for all the times they tend to go out.
Yup, that's pretty good for $35.00. I just bought a set of 8mm silicone wires for mine from Rock Auto, and they were $25 plus shipping.
Last but not least, the fuel sending unit and (I forgot to mention them earlier) a set of good wires I pulled off the motor.
The wires are "premium silicone", and strongly resemble the Borg Warner Select wires I have on the car right now. I will keep these around as spares in case of an emergency or troubleshooting purposes. Can't beat $2.00 for wires! :)
My receipt...
Dash - $15.00
Floor pan - $5.00
Mud flaps - $5.00
Fuel sending unit - $10.00
Wires - Free!
All in all, I think I did pretty good for $35.00! ;D
Here are some shots of the mud flaps and the floor pan.
The second photo of the mud flaps shows a comparison to the size of the flap I pulled off the Bobcat this summer. It was a Datsun flap, but it was cut well enough to look good on the car. It is what I am using as a template to cut new ones out of the Jeep set. I have flaps on the rear right now, just need to get the front done.
The second I removed from the floor wasn't much, as I don't have very much rust aside from the section that has holes through it. I should have enough material on this donor pan to overlap the good metal and weld it on.
I got two of those bits at Harbor Freight for $3.00/ea. today. not to bad, and I may end up going back for a couple more before the sale is over, but we will see how well they work first.
Here are some pictures of the goodies I pulled from that Bobcat wagon I have been stripping down since August. The only thing I might want that is left on the car is the cowl vent. Other than that there isn't much left of the car aside from glass, the body panels/doors and the drive train (engine, tranny, axle, etc.)
First the dash. I had already pulled most of the dash which is in storage. The radio bezel, dash cap and vents were sold to other members, I do have the wiper switches w/bezels, and the gauge cluster bezel though. The glove box door was already taken or was missing before I found the car.
The close up photo shows the only real damage to the dash. There is a light scratch here and there, but barely visible. I buffed up most of the paint, all but the nooks and crannies, on the front and half of the top.
Dave, the drill bit is available on the tool trucks, (snap-on, mac, ect) not sure of the price. It is a double-ended bit so you get to wear it out twice!  ;D
Got to visit my friends at the parts counter at Ford today and figure out some info on fuel sending units. Here we go....
D9FZ-9275-A
(non-wagon) 77-79 Pinto - 4cyl only
                   77-78 Mustang - 4cyl only
(non-wagon) 77-79 Bobcat - 4cyl only
D7ZZ-9275-A
(non-wagon) 77-79 Pinto 6cyl
                   77-78 Mustang 6 or 8cyl
(non-wagon) 77-79 Bobcat 6cyl
Wagon units are different, but I could not get the part numbers or interchangeability for the wagons, as the bulb for the microfiche blew out.
If anyone needs a 77 Bobcat Wagon fuel sending unit, let me know! :)
I'll let you know tomorrow how it works out, Phil. I got your voicemail but have been a bit busy, and my black friday trip was my only time away from work all week. I will call you Monday about that part.
My local harbor freight  carries them in stock and the price was  about $4.00  but  i haqve not tried it  yet.
I couldn't find that special drill bit at sears or home depot, but I will check harbour freight for that other one, which is available on their website. It appears to just be a very small hole saw (I am more familiar with hole saws 1-6 inches).
I believe I saw that for sale at Harbor Freight for about $4.00. It may only be a cheap brand but I'm sure it would do the job.
map351
Try a Blair Double-End Spotweld Cutter..  The Blair does a nice clean job of removing the spot welds and the panel..
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Quote from: dave1987 on November 29, 2008, 11:53:31 PM
Apparently a sawzall isn't even allowed at the yard I frequent, but they told me that AFTER I cut the floor out. I guess I will have to find another way to cut floor pans in the future. :(
It called a hammer and several very sharp chisels!!!!!! LOL  Our yards don't allow sawsawls either!  We had to hammer and chisel the front clip out of a car once!!! Pretty fun!!! LOL
71pintoracer, thank you soo much for the heads up on the special drill bit, I now know how I will pull the cowl vent from the car at the yard! ;D
I will try to get pictures tomorrow. It has been a long day getting things done.
If all else fails for the sending unit, at least I have a spare for someone whom might need one. :)
There is a special drill bit made just for spot welds, it is kind of flat on the cutting end so you can just cut thru the weld and outer metal. Then use your air chisel to cut away the unwanted part.
I believe the sending units are different  from a wagon to a sedan the tanks are  and the parts book has a different  # for them.
Dave,
  There is a tool specially designed for cutting out spot welds. On the other hand, I used an angle grinder and ground out spot welds when I made replacement panels for my Pinto floor. Basically I used the grinder on the discs edge and ground where the spot weld showed.  You need to be careful not to cut too deep into the metal you want to save. However it is inevitable that you will grind some of it.  It will take some time to accomplish.
Tom
Well I got the pan cut out today, so I can repair the rotted section of my floor when I have my windshield replaced!
While I was there I grabbed the fuel sending unit. I do not know if a Bobcat wagon unit will work with a Pinto sedan though. If anyone knows, I would be happy to hear! Any ideas on how to test it?
I also grabbed a set of mudflaps off of a Jeep Cherokee that I can cut to the shape and fit of the Pinto, so hopefully that will protect the quarter panel on the passenger side that is starting to rot.
Now, how do I go about separating the the sub frame from this floor pan?
You paid $1.88 for an Omni GLH Turbo hood vent?!? Now that is a find and a half. Those suckers go for $40 easily! On the other hand, may another GLH rest in piece.. such a waste since those cars are rare in good shape.
Well..., I went to the Pick A Part 50% off sale on Thursday in Sun Valley, CA..  It never rains in California (Southern), but it did this week.  Everything was wet and the yard was strewn with parts because no one wanted to go out in the rain and clean it up.
Anyway, only one Pinto (1973 wagon) and it was rather gutted.  The glass was good, and if you want an early style sway bar... .  But that was about it.  No Mustang II's either. I've been searching for a way of getting air to the turbo intercooler (stock T/C) and have been hoping to find a Nissan 300 ZX hood scoop that is an ideal fit.  No luck.  I pulled the intake grate off a turbo Dodge Omni ($1.88 out the door) and while it fits the intercooler footprint it looks like a BBQ grill.  There is no real ducting of air (like a scoop), but it looked like rain and leave have an easy ingress. At this point I'm going to proceed with using a single T/C scoop.  I mapped it out today.
So, my "black" Friday was a dark Thursday.  Oh..., wait..,  I did pull a vacuum fitting off a Mustang 2.3.  I ground the top of it, and filed the treads in my lathe.  Now rather than the stock T/C fitting hitting the hood I have nearly 1/4" of clearance.  Ahhh, the silver lining in my cloud.
All the best with the floors.  Someday I have the same planned for my Corvair Wagon.
Tom
You have a wicked sense of humor there, Kim!  LOL :lol:
