71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 12/26/2016 04:29 pm
79 pinto steering column
Date: 08/18/2018 02:00 pm
SVO SWAP
Date: 03/15/2018 03:12 am
1973 Pinto Wagon
Date: 05/06/2022 05:13 pm
Date: 01/18/2017 05:35 pm
Date: 04/12/2017 06:57 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
  • Online today: 1,292
  • Users: 1
  • Guests: 365
  • Total: 366
  • warhead2
The Baby (aka the copper queen)
Started by blupinto, November 28, 2008, 09:41:14 PM
The only way I have been able to identify stock Pinto gas caps is to put it on the car. If it doesn't go on straight after turning it all the way, then it isn't Pinto! :P
I have done this with Mustang and Ranchero gas caps at the JY to check them before I purchase and neither fit the Pinto correctly.
Oops! Forgot to get pic of new item... it's a gas cap, but I'm not sure it's a Pinto gas cap (sure looks like one!) It's even the same color as the car. Are there any identifying stamps or marks on the original Pinto gas caps? (FoMoCo, Ford in oval...?)
           Meanwhile I'll manually close the butterfly (after the car's warmed up, as at this point the butterfly is wide open) but as soon as I depress the accelerator the BF opens wide again and the car won't start. When she cools off she's ok as long as I didn't kill the battery attempting to start her.
the Butterfly at the top of the carb should close almost all the way, until the car starts to warm up then progressively open to allow more air.
The poor Baby.
I've been trying to drive her around here to a) keep her battery charged and b) keep her juices flowing toi keep the seals from cracking and/or leaking. She runs ok once she's warmed up. It's later that she bogs down and stalls. I'm now convinced it's the carb or the linkage from the throttle. In warming up the engine responds with a mere tap on the accelerator pedal (in idle). The butterfly isn't closing but I don't know enough about carbs to know if that's good or not.  :read: :'(
       I got a little something for her at the swap meet Saturday. I will send pic tomorrow.
Hey Dave!
         The plastic in the armrests actually broke. The sheetmetal is fine. Right now The Baby is sporting a powder blue one on her passenger side til I get a pair of bronze ones.
Quote from: blupinto on December 08, 2008, 09:58:56 PM
I can look for a battery tray... The ones I've seen have been nests of dirt and pine needles.
Thanks. Whenever you get a chance, but I'm in no hurry. It doesn't even have a tranny in her at the moment.
blupinto, what is wrong with your armrests? Is the top part not staying screwed into the door? Or is the bracket that the bolt goes into missing from the door?
On my car, the brackets tore away from the door and ripped so much sheet metal around the holes (that the brackets clip into), that I can't use brackets anymore unless they are welded into place. For the time being (until I get new doors), I am using a 1" thick piece of wood screwed to the inside of the door, and the armrest bolts screw into that. It works quite well, at least as a temporary solution.
I have a battery tray froma 75, Not sure if its complete tho. I will get a pic and post it in another thread later on tmr.
That's fine & dandy if the only thing in the tank will be rust, but unfortunately there is more than likely some regular dirt in there as well. Unfortunately the best way to clean the tank & the only way to prevent the issue is to drop the tank & clean it out. I say unfortunately, not because it's difficult to get to, but because you have a full tank.
Off topic, do you know if there were any good battery trays on the Pintos in the junkyards? Tryin to track me down a decent used one & there are no yards out here that have Pintos. Stupid rust belt lol
Quote from: blupinto on December 08, 2008, 09:14:40 PM
Don't worry about labor. It gives me an excuse to go to the wrecking yard! ::)  I forgot how fun it is to hunt for parts. The stuff you find in the process... I think I'll be going next weekend and I'll grab 'em.
         Someone at work suggested I put a speaker magnet or two on my gas tank and the metal bits in the tank will adhere to it from the inside.  Thoughts?
Cool, no hurry though. We'll pm when the time comes!!! :D
As far as the magnet, it sounds like a good idea to me, but I am no expert on gas tanks!!! LOL ;D
Quote from: blupinto on December 07, 2008, 08:51:01 PM
No problem...
     Sport mirrors... well why didn't you say so!?
I found a few Pintos and others with their sport mirrors intact. None were green, so if that's not an issue, then I'll be happy to grab you a pair. Will you be needing the toggle switch (remote like I have)? I can't promise I'll find that, but I know I'll find mirrors.
I guess I should go with the non remote style. But then again, maybe I should get a set of both styles!!! LOL  Let me know what they are going for at your wrecking yard!! I'm going to guess around 10 -15 bucks to ship. Oh, and most importantly, how much for you to do all the work!!!!! :D
Thanks!!!
Looks like I'll be shoppin' for more tools. Thanks for the tips. Provided it doesn't rain in the near future I'll pull the stuff off (plugs, distributor, ignition box).  I believe the wires are brand new. The distributor cap looks new too. Still, I'll investigate. Sure wish my garage was cleaned out...
the Fuel filters will only take care of some of the "gunk" and you will be replacing filters quite often, best bet is to get the tank down and out make sure there isn't any gas in it, and look inside and see what Rust/other stuff is loose in the tank, you can use" if there isn't a Plastic liner in the tank" B-12 Chemtool to clean it out a little, to rinse out that loose mess so its not being picked up by the pick-up tube.
As to the hesitation/misfire that could be timing but can also be lack of fuel delivery, (you stated you had to feather the pedal). If i can help i will anyway i can, as to sport mirrors I have one set and they are on the car. "if" I find the Pinto guy out here (hes got like 20 in his back yard) I will let you know if i can snag a pair from one of his parts cars.
Not sure what the part is but the socket you need is a 5/8" spark plug socket. The spark plug socket is a deepwell socket with a robber insert. That insert keeps the spark plug from hitting the inside of the socket, thus preventing damage to the plug. You'll want to check the gap when you pull the olugs. Look at the center electrode & firing tip. If there is any sign of wear a.k.a. rounding or errosion then you will want to replace them.
Also check your plug wires for any burn marks from arcing. Replace any that have any signs of arcing from spark flashover.
Lastly pull off the distributor cap & take a look at the inside terminals, as well as the rotor button. If there is any sign of wear or pitting on the terminals then you will want to replace them as well.
Almost forgot.. You might want to remove the ignition box from the car & have it tested. Auto Zone & Advance Auto should be able to check it & it's free.
Sounds like a vacuum leak somewhere.
My 2.3l 78 Sedan had a similar issue, but it is a 4spd stick shift.
In my case, it would run fine when cold for about the first five minutes. Once it started to warm up though, it would idle rough and miss. In my case, it turned out to be a cracked EGR valve. I'm guessing the vibrations from the engine would rumble it loose after running for a few minutes, then the crack would widen. When I removed my EGR valve, it fell apart into two halves and the vacuum leak became very obvious. :P I have since removed the EGR valve and have a replacement one with the EGR tube set away for when emission testing time comes along. I don't have it on the car as it makes acceleration sluggish and I get better fuel economy without it! Occasionally I will put a sealed oil cap on the valve cover, instead of the vented one, to enjoy a bit more low end power (which is nice when it snows and ices over, for cookies!). ;D
I really should be more patient. I hadn't finished...
I goofed around in the engine compartment and decided to see how she runs. I turned the key... and she started right up!!! Not only that but she didn't shake nearly as much and stayed running without me feathering the pedal. I put her in drive and she rolled on her own in idle! I couldn't believe it! I drove her in the neighborhood to test her further and soon she started hesitating again and missing. When I backed back into the driveway and put her in park her idle sounded no different than when she was in drive. Hmmmm.........
No problem...
             Now for the tank o' gas: I'm sure there's gunk in it but the choke is stuck open instead of freely opening/closing.
         I reconnected those mystery hoses (see mystery #1) and adjusted the doohickey to the right of the carb (help! My Chilton's in the garage and I don't remember what that component is called!) There's a hose attached to it that contains coolant. I wanted to pull the plugs to get a look at them but my standard plug socket is way too big. My other sockets aren't deep enough.
Quote from: r4pinto on December 07, 2008, 05:17:19 PM
No Kim, I am sad to say it won't. In 2006 I drove to Carlisle for the 2nd Ford Pinto meet but was towed home. The carb I rebuilt a week prior to Carlisle was filled with rust & junk. There are just too many fine particles in the tank that will get caught in the carb because they get past the filter.
Ok, well then if my new carb doesn't help, I will think about pulling the tank and having it cleaned. Good thing I know a radiator guy!!! ;D Sad thing is, I just filled her up, and without being able to really drive her, I will have to drain the tank!!!! Yuck!!
Oops, sorry blupinto, a little thread jack there!!! LOL   :D
Sorry to hear about your bad fortune heading to the "beanery" (love that word)!!! I too am kinda in the same boat, as you know. I just bought a new carb from ebay and am going to wait to get it before I do another venture out in the green machine!!!
Now I have to say, you are so lucky to find Pintos at wrecking yards!! I can't find anything up here in Northern CA. My hubby has people looking all the time now, and nothing! Well we did have a false lead that one time! I'm looking for sport mirrors if you ever find any!!! :D
Now about the tank, wouldn't a good fuel filter take care of the crap in the tank??? To some point that is??  I put a new, clear, filter on mine and my gas is looking pretty clean! Wouldn't it show gunk in the filter if there was gunk in the tank? If so, you may want to put a clear filter on to see if there is gunk in the tank!!
Good luck with her, keep us posted!!!
Awesome tip there. Why clean out the carb if the junk in the tank will just get back in there.
another tip would be to make sure there is no gunk in your tank, if its in the lines it can make it seem like the carb has trouble. (learned this with my old dodge ramcharger.
Wow!
Sounds like you had a great day at the junkyard. Nice finds. Sorry to hear of your problems with your car, but atleast she is easy to work on. Who knows it might actually need a new timing belt on her. Good thing it's easy to replace.
Well, she did it... she crapped out on me.
I noticed she was a little "off" when she was about to go into 2nd gear. Acceleration in 1st was the same, but in 2nd she lost power like she wasn't getting gas and would stall on the roll. She couldn't make the mile to the beanery. AAA to the rescue! The driver was knowledgeable about Pintos (he had a '76- his favorite car) and currently has a '73 he just acquired) and told me it's the carburetor and its components, plus timing. He gave me pointers on how to do some minor adjustments, but it needs more than that. WE did go to get gas, but she only accepted 2 gallons, so I don't think it's an empty-tank issue.
          While waiting for help to arrive a kind older Hispanic gentleman told me of his three Pintos and how good they were.
         On a better note, I did go junkyard shopping and found a "woodgrain" shift bezel, a steering wheel horn piece just like mine (except it's missing the "woodgrain" trim sticker), the piece that connects the crimpy hose from the air cleaner to the air filter, another rearview mirror with less blemished glass, and a couple pop-out window gromets (?) from a '73 station wagon (a beauty! If money was no object...) So while the Baby doesn't run right, at least she has some "new" stuff!
As a matter of fact I do have a Maverick emblem or two.  I might even be able to wrestle up an interior steerhead door emblem too if you wanted one. Back in the early '90s  when our beloved cars were plentiful in the wrecking yards I was grabbing emblems left and right.
          Thank you for the pre-heater duct info as well as the info on the plug and steering wheel. I guess I'll connect the two things and we'll see what happens (hides her eyes). :lost:
The orange hose can be  picked up at most parts stores  I believe it is called a pre heater  duct   replacements are silver and  cost about $5  maybe less  it was 3 yrs ago i bought mine.  The plug is a mystery as mine has the same thing and  i have not figured it out yet. The  2 pieces  if i see them correctly (the hoses)  yes they do connect it is part of the heating  cooling   they  go from the heater core to the manifold to help warm up the  carb a car with   factory ac  has a "H" pipe there.
The steering wheel  according to my  parts book  is a very common one used on many  fords,mercurys  in the 70's  the difference is the horn pad  and yes it  very well could be leather on your wheel  that was a factory  option  in a few years.
Maverick parts  i would like   emblem( for a cork board in my garage i have a pinto, bobcat , mustang, ford and mercury emblems on it now) and an original gas cap  with a maverick  symbol or script. mine was changed to a mustang cap. i will need more  but start small  if by chance you find a tan interior   i need alot more.
Thank you Dave. I'm not sure that's the original carburetor or not, and so far I don't see anyplace where that plug should go. I haven't had an old (20+ year old) car in 15-16 years. Wait I did have the Maverick. I don't really count that because I wasn't able to get her registered (she's gotta run to be smogged, right!?) and thus she wasn't enjoyed to her full potential. In fact I resented her long after I sold her to someone who thought they could get her running. Even they threw in the towel. I had a miserable low-paying job so I couldn't afford a proper mechanic to look at her. She was nice otherwise...
       Wait.....Did i hijack my own thread!?!
   It would be nice if that intake piece was intact, but I'm glad that's not the reason it runs so roughly.  As long as it won't be detrimental to the ol' engine. Thank you for easing my mind. That (that hose) will be on the Santa list too.
