1975 Ford Pinto
Date: 01/13/2020 11:02 am
Date: 05/24/2020 08:19 am
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 08/01/2018 01:27 pm
Date: 10/14/2019 08:24 pm
Date: 04/20/2017 10:10 am
6.6.75 carrier
Date: 02/14/2018 06:47 am
Date: 03/23/2018 09:23 pm
Wanted 73 pinto squire wagon
Date: 05/09/2020 11:59 am
  • Online today: 178
  • Guests: 169
  • Total: 169
brakes
Started by miked1989, November 28, 2008, 07:49:10 PM
XCorePintoLover
To check your lines which might have small holes letting air in, stand over the master cylinder while having someone pump the brakes and look for bubbles in the brake fluid. If you don't replace the lines you'll have to keep putting more brake fluid in, I do mine almost weekly because I have yet to replace them.
Until recently, I drove a '79 Bahama Blue 2.3 Automatic Hatch.
Is the proud mommy of a baby girl, Haylee. :D
Miked1989:
  I concur with Bill (above) that the brakes are very important - if you are unsure of yourself in any way, have a professional do it, or have someone with first hand knowledge help.
  I myself went through a reasonably exhaustive brake system overhaul about a month ago; all new rear hardware/cylinders, rear hoses, returned drums, and new master cylinder/front hoses. I've yet to "dig in" to the front disc brakes, I'm just glad to have brakes again.
  Good luck with yours, be very cautious and proactive when working on your brakes, have the right tools, and be patient.
Quote from: miked1989 on November 28, 2008, 07:49:10 PM
.....i have no experience with brakes first car....
Bring the car to someone that has experience and can do them for you, or help you do them. Brakes are TOO important.
Matt gives some good info too. I normally don't swap out calipers or other items until I inspect them.
Glad to be of assistance  :D I know I been where you are at. Good luck on your project.
miked1989
77 pinto first car!
For the fronts you will need new pads, calipers, rubber hoses.. You will want to get the rotors checked to make sure they are useable, or just go ahead & replace them as well. It's a good idea to repack the wheel bearings while you have the brakes apart. It'll be easier to repack them now while you have them apart, than having to take it all apart to repack or replace them. You will need two inner wheel seals to do this.
For the rears, you will need new shoes, rear brake hose, wheel cylinders, hardware kit and possibly drunks. Just as you can get the rotors checked you can do the same with the drums.
You will also want to get lots of brake fluid so you can bleed the entire brake system of all the old fluid. You may be asking why if the car has a good pedal... The answer is simple my friend. Brake fluid retains a certain amount of moisture, which will lead to rust AND brake fade. You bleed the brakes to get air out of the system as well as the old brake fluid.
The Haynes manual actually has good info on the brakes so you should be able to refer that if needed.
miked1989
i have the basic stock brakes i would like to rebuild them. car has been sitting for two years has rust on rotor. i have no experience with brakes first car what would i need to rebuild the brakes both disk and drums 4 lug
77 pinto first car!
