  • Online today: 153
  • Guests: 127
  • Total: 127
wont start died when driving
Started by sandrailsteve, November 20, 2008, 09:45:10 AM
bad coil ? trying to figure out any help would be greatful
bad ignition
1 (50%)
bad coil
1 (50%)
Total Members Voted: 2
sandrailsteve
it well be in shop today well let every one no what it is thanks for all helppppppppppppppppp
Lost Coz
Might be something as simple as a bad cell in the battery. 12 volts doesn't sound like a good battery, it should be above 12 volts if the charging system is working correctly, probably around 12.5 volts. If the battery isn't right, the MSD ignition won't work correctly, as stated above, you need 12+ volts constant to run the ignition. The battery will drop voltage rather quickly if a cell is bad and a load (fan) is turned on. Just a thought...
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
The key word here is "voltage drop", could be power or ground side, when you add a load to the system, (the fan) the volt gauge goes from 12 (which is low to begin with) to 9, meaning that the voltage path has high resistance. The ignition system needs a good 12v to fire, especially a MSD.
sandrailsteve
i dont think so well have to check on it though i just got this ride not to long ago thanks
sandrailsteve
kind of stuck when it was running before it died turned lights on went real dim came off and on again this is why i thought it was alternator or battery which i switched out and took alternator off had tested said was fine when i was driving it volts dropped from 12 to 9volts when fan came on even today tried to jump start it with other car turned fan on its on a switch dropped volts again  i put a bigger fuse in the fan i dont think has anything to do with it  with fan on  again before you new it battery was dead again when hooked up to jumper cables with other car running i think it is 2 seperate things no spark and maybe bad ground now anyways back at it again well go to shop soon has im getting tired of it more i work on it more beer i drink which means wife on my but  thanks lol
If it turns out to be a bad ground, be sure to check your coil and ICM.
A bad voltage regulator COULD fry the battery but leave the alternator intact. However, unlikely.
This happened to mine a year and a half ago while driving my ex home and it took me three days to figure it out after tearing apart the wire harness to find a short. :( In my case it turned out the voltage regulator went bad a little while before, and I ended up frying my whole charging system including the battery.
sandrailsteve
no spark checked it i think ground sounds right im going to check on it thanks for all help
Sounds like two different issues, battery going dead, then no spark. Maybe a ground problem?
PintoDriver
You sound like you're on the right track...have a friend ground a spark plug wire to metal and crank the engine to see if you have spark. If you do, then check to see if you have fuel going to the carb....or it could be your fuel pump. Disconnect the fuel line from the carb and put it in a container, and then crank the motor. Check to see if you get any fuel in the container, if you have spark, and fuel, then it might be the carb....hope this helps.
1980 Cruising Wagon
1980 All Glass Hatchback
sandrailsteve
i no this is not a pinto but has a 79 pinto 2.3 engine with many upgrades hope no one is offended anways i was driveing just died it did jump start one time right after has soon has i gave it gas it died wouldnt jump start sense notice my volts were low when fan came on they dropped one volt thought was alterntor had it checked says good changed battery new i have no spark thinking coil ,ignition has a msd 6 ignition and coil had a msd dist put a stock one thinking might be that im stuck before start buying parts figure i would ask some people who no pintos thanks again
