1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 12/10/2017 01:14 pm
1972 pinto grill
Date: 02/27/2018 12:13 am
front end parts
Date: 03/30/2018 12:48 pm
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 12/31/2017 09:03 pm
2 Pinto Wagons for Sale
Date: 10/29/2018 02:02 pm
  • Online today: 531
  • Guests: 209
  • Total: 209
77 pinto wagon starter
Started by miked1989, November 16, 2008, 09:35:27 PM
miked1989
oo ok i think i know what you are talking about thanks
77 pinto first car!
If you would like to replace the 'heat shield' with something newer and something that may work a bit better than stuff that is pushing 35 years old, try using some of the protective covering racers use to cover spark plug wires to protect them from tubular headers.  Not sure what the actual name of them is, but if you explain it to the parts counter at your local auto parts place, they should know what you mean.
miked1989
77 pinto first car!
Go to your local parts store and get a battery cable with an eyelet on both ends, take the covering off of the old one and slide it on the new, I don't know of any replacements that come with the heat shield cover.
miked1989
its the 2.3l and its the wire that bolts onto the starter
77 pinto first car!
Not a problem.. Pics generally make it easier so I'll just take a stab at it..
First off is what engine you have in it?
Second, Are you referring to the wire that actually bolts to the starter itself or one of the wires at the solenoid? That'll give an idea so you can get the right information.
miked1989
I'm sorry but i don't atm I'm living were i cant work on the car. i can get one but could take like a week to get the pic of it on here.
77 pinto first car!
Do you have a picture of what wire you are referring to? That might make it a little easier to pinpoint and give you an accurate answer.
miked1989
when the engine was dropped back into the car the started wire got all messed up. were would i go about finding a new wire n shielding that covers the wire?
may sound stupid but my first car no exp before
77 pinto first car!
