1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 06/28/2019 09:14 pm
Date: 02/08/2018 02:26 pm
1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 06/18/2018 03:47 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 01/20/2018 07:51 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
  • Online today: 1,972
  • Guests: 994
  • Total: 994
what trans does everyone have in their Pintos?
Started by matt68, November 12, 2008, 07:05:31 PM
bbobcat75
i have the good old stock c3 in mine!! its a crusier not a racer!!
1975 mercury bobcat 2.8 auto
earthquake
Quote from: douglasskemp on November 14, 2008, 11:02:33 AM
True, however, the A4LD will fit the 2.3, and it is an automatic transmission with an overdrive.  It is basically a C3 with a French made O/D unit added to it.  Not sure if it'll fit in the Pinto trans tunnel though as it is quite large physically.  They can be found in many late 80s vehicles that could be had with a 2.3, like Rangers, T-birds and Mustangs.
Also realize everyone, that 75bobcatv6 is putting in a 3.8L S/C motor in his ride, so his WILL have an AOD as it is a different bell pattern.
http://www.fordpinto.com/smf/index.php/topic,11038.msg70321.html#msg70321
Yes doug is correct I am installing a 3.8l Supercharged motor into my bobcat =).
Quote from: Turbo Toy on November 14, 2008, 04:04:46 AM
AOD does not fit the 2.0 or the 2.3. Sorry.
Quote from: 75bobcatv6 on November 13, 2008, 10:14:52 PM
My C3 is pretty good, but i am Going with the AoD trans that came with my new motor.
Turbo Toy
Reed
Is there an AOD that will mate to a 2.0 or is it a 2300 only tranny?
apintonut
pic of c3  u can see the third line c4 dose not have this if u are looking at a ford trany and it has this line it is junk!  c3 / a4ld
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
How do you tell a C3, C4, and a A4LD apart? I got burned on this once...
Anyway, I had a C3, but now it's a WC T-5....
apintonut
Quote from: TIGGER on November 12, 2008, 07:08:52 PM
My 79 V6 parts car is an AT but I am not sure what it is.  Do you know the data tag trans code number for the C3?
the best way to know if u have a c3 or c4 is the c3 has a 3 line on it it is a by pas line
this is a easy way to tell at a glance and good yo know if ur shopping for a trans for your pinto
c3 are good for ur scrapper not much els
i have im my cars c4 /c3 /t5/4 speed
Stock 4 speed, original clutch, Stock 2300cc with 2 barrel
Still cruisin' on the factory 4-speed!  :fastcar:
Reed
Well, three have the four speed standard shift, and one has a C3.  I do have a C4 out of a V8 MII and a 2.3 bellhousing that will most likely either go behind a 2.3T, or go on eBay, after, of course, it has been offered up on here first. :D
My '72 has its original 4 speed, mated to its original 1600 cc engine.
Stock C3 with the V8 valve body. has a nice Stiff beefy Shift.
turbo74pinto
My 71 was born in San Jose with a C-4. About to install the "European 5 Speed" Type 9 out of an 87 Merkur. ;D
I don't have a transmission in my car.  It is sitting next to the car & that would be a C3.
PintoDriver
1980 Cruising Wagon
1980 All Glass Hatchback
A built C4 with reverse pattern and trans brake in one car. A T5 from an 84 SVO in the other.
map351
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
matt68
matt68
Just wondering if anyone has anything but the C3 in their Pinto. My Bobcat has the 2.8L V6 and it has the C3. Anyone have a C4 in theirs?
  Thanks
