Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 04/14/2023 06:15 am
cam pulley
Date: 05/30/2018 04:56 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
1977 Cruiser
Date: 06/29/2019 06:28 am
Date: 12/20/2016 10:47 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
ford pinto door panels
Date: 03/20/2022 07:51 pm
  • Online today: 450
I got her!!!
Started by blupinto, November 11, 2008, 11:13:29 PM
Hey again...
          I took a little trip to the local junkyard today. It was a bittersweet experience for me. I went there hoping against all hope I would at least find another set of window cranks (The Baby is missing the knobs from hers) and came across a (sob) '72 Pinto in Grabber blue like my first love. This one didn't have pop-out windows and had a WAY straighter body but was otherwise the same. I was bummed to see her there. However, a little bit of her will live on in mine. She had the door trim that I needed as well as the window cranks (someone took them off to get the inner door paneling). While I was rooting around in the cab I found a nifty Pinto floor mat (see picture).
            When I was done salvaging from the Grabber blue one I spied a '76 Mustang ll. I think the windshield will fit the '74 Mustang ll I'm getting in the not-too-distant future. While I was there lamenting (again)- this time about why would someone sacrifice a Mustang with metallic blue (mmmm) interior when I spied a pair of ford Mustangll-Pinto aluminum mag wheels with the black stripe around them. Yay! Now I have a set of four. They will need to be cleaned big time. Is it possible to make these guys really shine like in their younger days?
                   If there's anyone in the Oceanside Ca. area interested, there are a pair of other aluminum Ford (?) mag wheels but there's no black stripe on them.  There's also a '77-78 powder-blue Pinto there but it's been there awhile.
Quote from: douglasskemp on November 12, 2008, 11:53:26 AM
Are you sure it is a toggle switch? Your car appears to have sport mirrors, and if there is a mirror on the passenger side, it may be the adjuster knob for that.
Quote from: blupinto on November 13, 2008, 12:27:15 AM
You are correct... it IS a passenger-side sport mirror adjuster.
:afro: SWISH!  :lol:
I had the same issue with my sport mirrors, where they barely moved. I sprayed a bit of liquid wrench on the pivoting parts before I installed them, and let it soak over night. After that they moved very freely, but not to the point that they become crooked when the car is bumped or during rough driving.
I do find that they are rather sensitive to adjustments though. I will move the toggle in a specific direction and the mirror doesn't respond right away, but eventually jumps past where I wanted it. Because of this it takes a little bit to get them adjusted correctly. Once done, it doesn't need readjusted though.
75bobcatv6, if you find somewhere to purchase new adjusting cables, I would be interested in them as well. Then I would just have to find out how to safely replace them without breaking anything. :P
i spy ac on that car. maybe the person meant it didnt work. but its there nonetheless
My '72 runs fine on regular unleaded, although unleaded fuel was not a requirement at that time.
You are correct... it IS a passenger-side sport mirror adjuster. I'll find any excuse to go out to see my new baby and this was a great excuse! The mirror doesn't move much but it does move. Thank you guys for clearing up this mystery. How clever is that- to have a pass. side adjusting toggle (?) so you don't have to reach across the car to make the mirrors right?! That's so coooooool!
                 I understand the 2.3 is more fuel efficient than the 2.0- Speaking of engines... nowhere on this car does it say "unleaded fuel only".  I'm guessing this takes regular gas.  What are my options in terms of fuel? Lead additive?  I remember someone told me when I had the '72 Pinto that after all these years the valves had hardened to where unleaded fuel could be used without damage. Please advise.
The switch should be for the sport mirrors, I have the same switch on mine, But I need a new Adjusting Cable as mine broke.
It looks to me like a 2.3 you have, judging by the air intake system and location of smog pump, etc...
Is that a toggle switch or the mirror adjustment knob for the passenger's side sport mirror? I know that my car has a hole for the adjustment knob for a passenger's side mirror, but my car did not come with Sport mirrors. Because I installed Mustang II mirrors on my car, the knob does not fit under the dash as it should. It looks exactly like a mirror knob from here....
Thank you Pintogirl!
               You're right- there really isn't much wrong with her- just some little things. I was told that she belches a lot of smoke from her tailpipe. She runs rough and I have to keep my foot on the accelerator pedal to keep her from stalling. Most of what she needs is cosmetic, like the vinyl trim on her sides, the transmission shifter plastic base is cracked in several places, Of course the dashboard is badly cracked, but she lived in the desert all her life, so I'm not surprised. THe rearview mirror needs to be replaced because the reflective part of the glass is cloudy.
                Now for those pix...
pic #1  is the toggle switch under the dashboard and instrument panel. The switch is between the steering column and the radio area.
pic #2 is the engine.
pic #3 is where the plastic piece for the pop-out window hinges are missing. The window kinda flops around (what, you've never seen a window flop around?! ;)
When I get a few minutes more I'll post more pix.
Congrats on your new baby!!! Doesn't look like you have to much fixing to do!! LOL She looks like she is in pretty good shape!!
I'm thinking the engine is a 2.3 because there seems to be more stuff in the engine compartment than I remember my '72 had (that one had a 2.0) The sticker on the valve cover is discolored due to a previous car fire (thankfully superficial). I know I have a '74 Pinto OM floating around somewhere but I'll be darned if I know where I misplaced it and its sister manuals. The ones on ebay look like the cover's missing (or I forgot what the '74 manual looks like.).
          The hatch works better than the one on my '97 Rodeo!  It stays up (okay, okay, so I need to change the lifts on the Rodeo. I'll get to it...) ;)
Hi,
       Sorry I didn't post pix yet of the motor or the toggle. The toggle switch, which looks like it's chrome-plated, is located under the dashboard closer to the driver's side. I'll send a pic tonight when I get home (I'm on my friend's 'puter). The car doesn't have a rear window defroster (I'm assuming that is the original window).  As for A/C, there's a sticker on the inside right wall that says "Air Conditioner" but the previous owner assured me the car has no A/C.  I haven't had a lot of time to really absorb everything in her.  Yes, I'll post more pictures very soon. Now that I have that reducer thing figured out... Thank you for the congrats.  I'm really happy with the car. I can't wait to start fixing her up. I also want to thank the nice lady who sold her to me. That lady is a firecracker!  She is happy that her little car went to a good home.
Congrats on the 74 Pinto!  She looks in good shape on the outside. Got any other pics of the car?
As for the owners manual, I bought mine for my 77 at a car show in Carlisle, Pa for $6. you should be able to find an owners manual for your car at almost any car show for a good price. Ebay also has them from time to time but they cost a little more that way.
dkpony79
My 79 has switch in that location next to column, mines for the rear window defogger.  Pull it towards you & lever lights "ON" ,do it again & powers "OFF". Do you have any wires in rear window?  Or might have been eliminated.  I did'nt know at first look.
                                              DK
I was going to say to that guy were dealing with Ford Pinto.  weired   Fred ???
Spam has been removed and this user has been permanently banned.
Are you sure it is a toggle switch? Your car appears to have sport mirrors, and if there is a mirror on the passenger side, it may be the adjuster knob for that.  Also, there does not seem to be any picture of an engine attached to your post. :D
It could be a rear window defogger. Just guessing.
NICE CAR!!!
I bought a Peugeot with a "mystery" toggle switch, after a year of playing with the switch on and off and listening for things 'clicking' and watching for something to turn off, I followed the wires and figured out it was for fog lights the car didn't have anymore. Congrats on the new car! Hatchbacks are cool and handy. Factory a/c? I didn't see a pic of your engine, it has to be either a 2.0 or a 2.3 given that its a 74.
Chuck :afro:
grats on the car, Where is this Switch? if it isnt the headlight or wiper switch its Probably not stock.
Hi All:
           A bouncing beautiful baby car was delivered to me today. A tow truck (er, stork) delivered a '74 bronzy-copper runabout at approx. 2 pm. She was bather and had attention lavished on her by her stoked mommy.  I have a few questions about the (new) baby- like what's this toggle switch under the dfashboard on the driver's side, and what engine is this by looking at a photo (the sticker is discolored from a previous under-hood fire). Also, she will need (new) parts, like armrests and a rearview mirror. I would love to find a '74 owner's manual too.  This time I hope the pix will show. Anyway, mommy and baby are fine...
