  • Online today: 1,972
  • Guests: 888
  • Total: 888
Front disc Brakes (4 & 5 Lug)
Started by turbopinto72, September 02, 2004, 09:15:33 PM
The 74-UP spindle are 1"+ taller than the early Pinto spindle.
I still wonder how much difference the 74 and up spindle has compaired to a 73 and down... if its a few machined parts it would open alot of doors for parts to swap.
Frank
I had a little different experience doing the upgrade to my 77. I purchased the kit with Granada rotors from rjays.com, and purchased the hoses locally.
I had to remove the dust sheild and had clearence issues with the lower control arm to the rotor. It looked fine until I put it back on its wheels and then it rubbed.
Also, I am using 14" alum. wheels with no problems; maybe the early cars need 15s with this swap??
gawdzuki
So from what i understand is... That the front brake assy, from 73 and earlier is different from 74 and later...
Well, thanks for the information. I am planning on going with 15" wheels and was thinking on switching to a 5 lug pattern. hmmm. Here is a question. does anyone know if the lower A arm can be replaced to get rid of the lower control arm. I though I saw it somewhere. Not sure.
  Well, I guess that it will be a little more research to get everything done that I want to.
Now, the down side to this project. 1) Modifying the brackets. 2) this setup is heavier than the stock 73 setup. The stock rotor is approx 9 lbs, the Granada rotor is 14 lbs. The stock caliper and bracket, loaded, is 7 lbs, the GM caliper and bracket, loaded is 6 lbs. Thats a net increase of +(-) 4 lbs per side. 3) You MUST use 15" or larger wheels to clear the calipers.
inside looking at the bracket.
Top front view.
An inside view
This is the top of the caliper.
Here is a head on view.
I did need to shim the bottom out also. It needed about 5/16".
Here is what a 74 and up bracket looks like on a 73. You can see the missalignment.
This picture you can see how much I moved the top mounting insert from the 74 and up bracket.
Front brakes part 2. Ive got the calipers on now. Here is what I did. I used a front caliper from a 1983 Monte Carlo Part # 208783-C160 and # 208785-C161. $11.99 + core charge of $10.00 each. I used a Duralast Gold brake pad # 529457 DG154 $ 28.99. You will need 2 pair of " brakeware" H5004 or Wagner F6074 or Bendix H5004 bolts that go through the caliper and allow the caliper to slide on the bracket.You need 2 , 1/2-20x2" 1/4 bolts and 2, 7/16-14x2" bolts to fasten the bracket to the spindle. You need 2 Brackets. This is a problem because Nobody makes them for 71-73 cars. For 74 and up you can use the brackets you can buy off ebay. I bought my brackets off ebay and modified them for a 71-73 type spindle. I cut the top mounting insert off, then mounted the caliper using the lower bolt. I threaded the top bolt into the threaded insert I cut off the bracket and used compressed air to move the caliper piston into its correct position. With the caliper firmly locked up on the rotor I tack welded the top bracket/insert in place. Then I took it all apart and welded the insert to the bracket.
The next few pictures will show you what it looks like.
RNRPINTO
MP Brakes warns you will need 15" wheels with the Mustang II kit. I want to do Granada rotors, will I need 15" wheels?
roadracebobcat
I know that the 1979-1982 Mustang 4 cylinder models used 10" brake rotors, and I have seen some Pinto racers (B-Sedan) with those rotors and calipers, with an adapter to use the Mustang caliper on the Pinto steering knuckle. It takes some engineering and careful thought. Probably heat treating, etc. I know it will work, because I have seen it. It will even fit in a 13" wheel.  Some SCCA racers should be able to verify this.
73wagon
 1. Why won't the later model rotors fit the early cars? I'm told all the bearings are the same. 2. Are the mounting points for early and late calipers the same? I know that the height of the spindle assembly is different but are the caliper mounting points different as well ?  Incidentally, Falcon, Mustang and Maverick 4 lugs are 4 1/2 bolt circle diameter like early Datsuns, Toyotas etc.
 OIC, I know the Mustang II had 4 lug disc rotors that will work on a pinto spindle. It would stand to reason that a falcon might  ???, not sure though. The probblem is that even though the " Hot Rod" guys use M II/Pinto spindles on their cars, They like the 5 lug pattern for better wheel options. Every Hot Rod supplyer I have called wont even think about doing a 4 lug, larg Dia. rotor and caliper set up becouse as far as they are concerned there is no market for it.
HighHooder
what I mean is that a Versaille or Granada swap makes for a 5-lug set up, as compared to the standard pinto 4-lug.  What other fords came with this same 4-lug disk brake set up?  It can't just be pintos.  I suppose if you live someplace where Cortinas are common you could rob them of their disk brakes...
I dunno, maybe I'm just thinking "out loud", but there HAS to be other sources for 4-lug disk brakes to swap into a pinto.
Proud owner of a 1972 Ford Exploder
Yes, there was a disk brake option from the factory. Im not sure what you mean by " availabe elsewhere as a 4-lug swap"  ???
HighHooder
Okay, so here's the deal... I have a '72 1600cc trunkmodel.  It has disk brakes, and by the looks of everything they are ORIGINAL EQUIPMENT from the MANUFACTURER.  I'm talking even my brake pedal has the "Disk Brakes" emblem on it.  I'm the third owner, it has 167k original miles, this car is still running the original clutch (yes, it's slipping and the t/o bearing makes a bit of noise).  I can't see any modifications besides a poorly done re-upholstery job on the drivers seat.
so, I guess what I'm asking is "Didn't these cars come with a disk brake option?"... mine seems to have ??? (and if so, wouldn't this be available elsewhere as a 4-lug swap?)
Also the same measurement as stock at the rotor surface to A arm.
Now comes the good part. I measured the same points as the factory unit to deturman if there is any difference in rotor off set. As you can see, there is NO DIFFERENCE. The same 3 3/4 " was measured from the A arm to the wheel mounting surface.
Here is a view from the back side. You can see the factory mounting holes for the caliper, which I will use on the new calipers.
 Now, with the dust shield off the rotor was installed. I used the SAME berrings and rear seal out of my stock unit. Yes they do fit and are the same size.
 Next, the rotor was fitted with bearings and pre fitted on the spindle. It was determined that the dust shield, where it fits around the back side of the rotor, hits. This does not alow the rotor to slide all the way on. SO, off went the dust shield.
This pic showes the stock unit and the distance between the top A arm and the rotor surface. This measurement is 2".
 Ok, Ive got the Granada rotors on. Here are some pictures of the rotor swap with measurements. This first pic is of the stock 9", 4 lug 1973 rotor. The distance between the top A arm and the wheel mounting surface is 3 3/4 "
Thanks for the info Dick. I have purchased a pair of Granada rotors and will be starting the swap soon ( 1973 Pangra). As allways I will have a ton of pictures and all the measurments you will need.
Late model Pinto (74/80) front  brakes can be put onto a 71/73 Pinto two ways. The 74/80 calipers can be adapted to the 71/73 spindals with a little machine work. Or the entire unit (spindal/caliper/rotor) can be adapted by useing different ball joints/tie rod ends. Changing the entire unit is the best way. I've done both with better brakes both ways.
