Date: 08/13/2021 10:39 am
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
75 wagon need parts
Date: 05/28/2020 05:19 pm
Looking for a 1980 windshield
Date: 07/30/2020 04:51 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 08/17/2022 06:27 pm
Date: 04/24/2018 11:45 am
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 10/26/2020 03:24 pm
  • Online today: 1,972
  • Guests: 1005
  • Total: 1005
Turbo computer wiring ?'s
Started by Wittsend, November 07, 2008, 08:41:55 PM
turbo74pinto
its just an orange wire with an eyelet.  it confused me for a few until i looked at the schematic.  just thought id through that out there as a reminder.
bob
Bob,
Got it fixed today.  It was the fusible link.  I now have 12V at pin #1.  I'll look into pin #49.  I'm using the stock 1988 T/C wire harness.  Shouldn't that be taken care of?  That being the O2 sensor hooked up correctly.
Tom
turbo74pinto
there should be a total of 3 yellow wires going to your possative post.  one to the eeciv and 2 to the ircm...or relay box.  do you have the 2 grounds hooked up??  also, dont forget to ground the hego when you get it up and running, its the orange wire, pin 49.
bob
 Thank you Bob.  The Turbo Coupe always ran (I had it for 15 years now).  Even though it sat the last four years I ran it for an hour before I ventured into this project.  Ironically I found the fusible link "fused" on that line (and it looked like it had been for a while), but like I said, it always ran.  Anyway, I physically fixed the fuse link, but perhaps it is bad in another spot.  I'll trace it down tomorrow.
Now, back to tracing the Pinto column wires into the T/C steering column... Ughhh. I sure hope the comfort of stalk mounted high beams, washer, cruise control and "tilt" are worth all the effort!!!
Tom
turbo74pinto
yes, the yellow, pin 1, should be getting constant 12v.  mine is currently on the battery side of the starter solenoid.  it will be moved directly to the battery this winter.
bob
  Well..., I'm sure this is the first of many questions regarding the LA-3 computer.  I do NOT have the computer installed and I am using the original 1988 T/C harness.  At this point I'm just checking voltages at the computer connector.
  By the way, I have every internet downloadable schematic known to man (I think). So, sending me looking for them is not the solution.
Question:
  Should I be getting 12 volts on pin #1?  As best I can tell the blue fusible link should be sending voltage down the Yellow wire even with the ignition off.  Is this correct?  I ask because I have no voltage.  If I turn the ignition on I do get 12 volts on the red wire (pin #37) - which I should.
I'll start with that.  I'm sure I'll be back later for more questions. Count on it!
Thanks,Tom
