Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Custom Pinto Project
Date: 06/12/2016 07:37 pm
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 09/20/2018 11:01 pm
Date: 09/17/2024 12:35 pm
Brake rotors
Date: 03/24/2017 09:02 pm
Date: 09/01/2017 07:52 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
  • Online today: 583
  • Guests: 339
  • Total: 339
Oil level
Started by fastfred, October 12, 2008, 04:07:40 PM
The specs say 4.5 quarts with filter and that is all I ever put in. It has always been at the full mark and not over.
Depends how much your pan is pushed in due to parking curb rash...  :accident:
Of course, if you have a sway bar you don't have this problem as bad.
From what I can remember, I had always put on an empty filter and used 5 qts.  It was always right on full after starting it up and letting it circulate.
The bottom of the "safe" mark on the dipstick is about 1 quart low, from there 1 quart will take it to the full mark.  I fill my oil filter almost half way before installing it.  be careful not to tip it too far and spill the oil out though.  Then I add 3 quarts, go in the house and watch a little tv.  come back out and check the oil and add as necessary, so I don't overfill it.
PintoDriver
The book that I have says 4qts, 4 1/2 with a new filter.
1980 Cruising Wagon
1980 All Glass Hatchback
fastfred
Just changed the oil and filter on my 78 pinto 2.3 motor.
I put in a little less than  5 US quarts.  After running the motor for several miles the oil level on the dipstick is showing about 2 inches above the full level.
how much does the motor take?
thanks  Fred
I
