Date: 12/30/2022 01:30 pm
Date: 10/10/2019 09:42 pm
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
1971 2.0 valve cover
Date: 01/25/2019 07:09 pm
Date: 01/21/2023 04:19 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 02/14/2019 06:27 pm
78 windshield trim
Date: 02/01/2020 08:46 am
  • Online today: 489
Leaky windows....
Started by Reed, October 05, 2008, 01:48:38 PM
So far so good on my rear window. If you read my post about "foggy windows" you can read exactly what I did to it. I was looking at everyone else's windows this morning (living with my parents right now) and they were fogged, but the Pinto was nice and clear!
Reed
Thanks!  I think i will need to do the silicone fix short term, until i can get new gaskets and spend the time to replace them.
Thanks!
Reed. I have been messing around with a white tube of RTV Silicon Sealant that I purchased from a Parts America store.
http://www.partsamerica.com/productdetail.aspx?MfrCode=PTX&MfrPartNumber=80855&CategoryCode=2132
I pumped a seam in m windshield gasket, about 1/4" wide, full of this stuff. We had some really heavy rain and snow yesterday and it didn't leak at all!
I wouldn't use it and leave it permanently, but as a temporary fix, it works great!
I myself need to fix my rear window gasket, it's leaking in around the bottom corners.
Reed
 >:(  Well, I discovered this morning that my 71 Pinto has a leak, at least one, on the passenger side of the windshield gasket.  This is in addition to the leak on the driver's side of the rear window gasket (I have a sedan, not a hatchback or a wagon).
The gaskets look okay on a cursory examination, but I haven't pulled the trim to look closely.
Is it possibly to reseal the gaskets without pulling the glass and replacng the gaskets?
If not, does anyone have good used (and cheap) front and rear window gaskets for a 71 sedan?  Mopney is tight and I need to get this fixed soon since I live on the rainy side of Washington State.
Thanks.  :P
