1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 08/06/2021 02:23 pm
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 12/09/2016 08:34 am
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Automatic Wagon
Date: 06/14/2019 11:22 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
Date: 12/09/2018 11:35 pm
Date: 03/23/2018 09:23 pm
  • Online today: 628
  • Guests: 290
  • Total: 290
need link to 5 speed changeover. 5 speed into a 1973,2.0L
Started by crossy, October 05, 2008, 09:04:40 AM
crossy
anyone know off hand what size hole(s) in the bracket for the cable to pass thru and the bolt below. I'd like to make one up here at  work today.  thanx , crossy
ehh ehhh ehhh FIRE! FIRE!
crossy
I FINALLY back after this project . needed it near the top. crossy
UltimatePinto
If your install has the pivot arm on the outside of the bell as part of the clutch linkage, you may have clearence issues with the crossmember, I did with mine.
Only certain bells have this issue. I cut a notch in mine, (crossmember), with a sawzall and welded a piece of steel square tube in it's place. Not all that hard.
Can also modify bell to fit the two top engine mounting bolts as the two liter's are lower and wider apart than the 2.3. Also did this with mine.
There are members who will also have the correct size bushings to use with the two locating pins for the bell to block allignment, as they are of different size.
The results are worth the effort. There may also be a relocation of the shifter where it comes into the cab, a little sheet metal work.
Al
In my '73, 2000, C-4, 6-3/4"   to   2.3, T-5, 8" conversion:
I use an '88 T-5 with a mid 80's bellcrank housing (which is what I think you are describing).
I used a cable from a 79 or 80 Pinto. I did make an adapter to elevate the cable over the crossmember. Hint, angle the adapter to better clear the crossmember. See picture attached.
I used the original driveshaft (and yoke) even though I went from a C-4 to a T-5 and a 6-3/4" to an 8".  It fit just fine.  :-)
Tom
72pair
I used a 74 up Pinto cable which is still available from parts stores. I had to make a slight notch for cable clearance in the crossmember. A 1" holesaw angled thru the corner did the trick. Good luck!
Note: A 6 3/4 inch rear end will take a different length drive shaft than a 8 inch rear. I had a Aerostar aluminum drive shaft ($17 at 1/2 price Pick Your Part day) shortened, high speed balanced, and new U-joints installed for $140 from Drive Line Service near Los Angeles.
I can tell you the C4 yoke will work.. I'm using one in the same tranny in a swap I did.
Best of Luck
FrankBoss
crossy
I got my trans from a 1990 , mustang 4 cyl., 5 speed. with the bell housing  and it has the funky transistion cable/arm that i am still not sure wether it works in Pintos or not.
FINALLY found a stock 2.0 flywheel(thanx pintoracer), pedals are here.(thanx Fred).
what size clutch & such do I need now?  since the spline on the 5 speed is different I suppose i order Clutch & PP for a 1990 Mustang??
I was told my C4 driveshaft is the one I need??
I sure hope this 77 MustangII clutch cable works because that is something else i didn't find.
Help me finalize this parts issue so i can get this in before the weather gets too cold for me to want to work on it. thanx , crossy
