71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 07/17/2019 05:23 pm
Date: 07/01/2019 03:17 pm
Date: 06/24/2020 06:12 am
Electrical
Date: 03/29/2017 11:37 am
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 04/28/2018 04:12 pm
Wagon rear quarters
Date: 06/17/2020 03:32 pm
  • Online today: 295
  • Guests: 142
  • Total: 142
Hotpants kit update
Started by map351, September 09, 2008, 02:19:32 PM
map351
302PintoMan
I'm trying to keep the original kit at under $600.00 + shipping.
I've made 2 front covers and they come out nice just need a little sand/file fit, I have to modify the mold a little to add a little more under the headlight for a little more bolt up surface.
If anyone wants a front bumper cover or rear spoiler I'm trying to get the Hotpants done before NMRA Ford Expo in Columbus I can bring the glass with me and save the you shipping! Front Bumper cover/spoiler $250.00, rear spoiler $95.00 this is a 1 time price for the NMRA. Speak up quick i only have 2 made and I'm running out of resin & Gel coat, the next supply order will bump up the prices.
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Map, if one of the front bumpers come out of the mold with damage around the wheelwell edge PM me. Im going to need to trim that area to work with my proposed flares so it can be damaged. Im in no hurry, Its gonna be well into next year before I get that far.
IIRC the whole setup was slated to be within the $600 range, but of course there'd be shipping on top of that.
302PintoMan
so what is the cost of the whole set up for a 75?  I SHOULD have the wagon/trunk trade done tomm.
I think the spoiler and such would REALLY set this car over the top.  Just need a cost guess-stamate to Texas  ;D
a true hot rodder wouldn't be content until he had created a car so violent, so hairy, so totally sick, that the very act of pressing the throttle, could result in instant death
map351
73 2.3Turbo Pinto
Pinto FiberGlass
wedge446
Quote from: map351 on June 12, 2010, 08:25:58 PM
Mold repair..
No matter how hard you try to get all the air pockets out they still end up in the corners.
Not sure if you tried but I use roven woven strains with some talc powder mixed in the gelcoat for the corners on my molds. I also use it in the corners of the parts.. Took care of my bubble trouble.
Just an idea
map351
Pulled my 73 out of storage today and bolted on the new FBC.
73 2.3Turbo Pinto
Pinto FiberGlass
peleus21
i have a 77 cruzin wagon but it will have a 76 bobcat front end on it when i am finished.
map351
Quote from: peleus21 on June 30, 2010, 07:57:30 PM
sweet so ... when you gonna start selling pieces? i wouldn't mind having to buy the front and sides now and the rear later...
I'm working on making the front spoiler fit the 79/80, what year is your car?
73 2.3Turbo Pinto
Pinto FiberGlass
peleus21
map351
Got the second FBC made and found a set of 1980 fenders.
73 2.3Turbo Pinto
Pinto FiberGlass
map351
Quote from: popbumper on June 21, 2010, 03:44:04 PM
MIKE:
  Can you explain how this mounts? Are the bumper brackets (on the front) that connect the metal bumper insert to the frame rails involved? If so, how is the mounting accomplished. If not  :lol:, how is the mounting accomplished?
Thanks, becoming more and more interested as this moves along. Would NOT mind losing my chrome bumpers in favor of this setup.
There's 8 mounting points, 2 where the grill filler attaches to the fender( out board),2 on the center grill support,2 on the upper wheel opening, and 2 on the lower fender supports. You can leave the bumper supports on and bolt a piece of tubing across to connect them for a little safety or just take it all off and loose some weight. I'm guessing the FBC weights about 7Lbs.
From the bottom of the headlight door to the bottom of the spoiler is 11".
73 2.3Turbo Pinto
Pinto FiberGlass
MIKE:
blink77
I've got a 77 sedan delivery with 79/80 front sheetmetal
and it is a direct bolt on. Bumper aborbers are a little
different. I have one of your lower valances on it. I think
it might adapt quite nicely to a 79/80.
map351
Quote from: popbumper on June 19, 2010, 09:37:07 PM
Simply. Incredible. WOW.
Thanks Chris!!
Now for a highly technical question? Will a set of 1979/80 fenders bolt on a 77 uni body? Just looking for alternatives if i can't find a 79/80 pinto close to me.
73 2.3Turbo Pinto
Pinto FiberGlass
The grille is a '76 (my personal favorite). I have 2 NOS ones. The headlight buckets are pre-'76 since they dont appear to accept the chrome trim on '76s. Looks like somebody ditched the endura buckets & stock grille.
Bumper looks killer....I cant wait to see one painted.
It may just work with the '77-8 headlights & grille....
Quote from: map351 on June 19, 2010, 12:22:34 PM
The built date is 6/77 it looks like all the front sheet metal is original?
if the build date is 6/77 then that is a '77 with the front headlights and grill of a '76...
a perfect example of what needs to be done to a '77 or '78 to make it work?? I would guess?
map351
Quote from: Cookieboystoys on June 19, 2010, 12:00:56 PM
Mike, the wagon is a '76
and it LOOKS FANTASTIC!!!!!!
Thanks Brian! The built date is 6/77 it looks like all the front sheet metal is original?
73 2.3Turbo Pinto
Pinto FiberGlass
Quote from: map351 on June 19, 2010, 11:05:35 AM
Cleaned up and fit. A 77 without the Ugly front bumper!
map351
mike
73 2.3Turbo Pinto
Pinto FiberGlass
/DROOOL man those are sexy i cant wait to see the rear bumper delete!
map351
First one out of the mold.. I'll clean off the flash tomorrow and mount it on the 77 wagon.
73 2.3Turbo Pinto
Pinto FiberGlass
map351
Quote from: Original74 on June 15, 2010, 08:09:56 AM
Mike,
You are such a craftsman, I am blown away with what you are doing with fiberglass. It is obvious you know your stuff. Thank you also for your dedication to making parts for the Pinto. I hope this community rewards you with purchases enough to make this worth your while.
Where are you located? I know you are not in Cuba, LOL.
Dave
Thanks Dave!
I just hate them big A$$ UGLY BUMPERS and I'm on a mission to do something about it! At the same time have a nice looking front spoiler that will serve a few different applications, the turbo guys with a FMIC a nice large opening, the Rally Guys big driving light openings or brake cooling ducts and a little better Aero front clip.
I have a rear bumper delete on the way too.
I'm in Leechburg Pa, But with this gang in DC it's beginning to feel like Mainland Cuba!
73 2.3Turbo Pinto
Pinto FiberGlass
Original74
Mike,
Dave
Dave Herbeck- Missing from us... He will always be with us
1974 Sedan, 'Geraldine', 45,000 miles, orange and white, show car.
1976 Runabout, project.
1979 Sedan, 'Jade', 429 miles, show car, really needs to be in a museum. I am building him one!
1979 Runabout, light blue, 39,000 miles, daily driver
map351
Mold repair..
73 2.3Turbo Pinto
Pinto FiberGlass
map351
Brian is correct on the 79/80 I'm going to fit this new front cover on a 79/80 front clip to see what needs tweaked to make it work. On the 71/78 this new FBC should be a bolt on with a early style set of headlight doors as stated in a earlier post.
I tried to eliminate all the differences in the front clips so this cover will fit 71/78. All you need is the 2 holes that attach the outer grill/bumper filler center grill support and bottom fender support. The FBC was mounted on a wagon with a built date of 4/77, I have a 73 and the first FBC will be mounted on it soon.
73 2.3Turbo Pinto
Pinto FiberGlass
Hey Dave, Mike said earlier that...
Quote from: map351 on March 04, 2010, 07:21:46 PM
front bumper cover/spoiler will fit the early cars up to 77.
the front end/fenders on the '79/'80 are to different/shape, '77/'78 I think would be a hard fit because of the headlight buckets but if converted to '74 thru '76 headlights and grill it might work.
So If I'm correct (Mike, correct me if I'm wrong) this front bumper/spoiler conversion would be the "hot part" for a '74/'75'/76 and maybe useable on the early '71/'72/'73 but I would be concerned on the '71-'73 because the dimensions and mounting on the early cars is different for smaller bumpers. Mike should know for sure on the early '71-'73's as he does have one to compair/look at...
Mike/Map has the final word on fitment but that's what I have understood (thoughts/concerns on '71 -'73 are my own) from previous posts...
dmsteen
map,will that fat a 79 wagon also?
apintonut
that will look so good on a 79-80 pinto
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
