Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 02/05/2020 11:06 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Date: 09/22/2020 11:33 pm
hood for a 79-80
Date: 11/30/2018 10:55 pm
1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
parting out 1975 & 80 pintos
Date: 08/24/2018 02:50 pm
  • Guests: 123
  • Total: 123
scale weight
Started by esoteric, September 04, 2008, 11:42:04 PM
LSXPINTO
Quote from: 71HANTO on October 22, 2008, 01:48:20 PM
A 351W weighs about 60LBS more than a simular equipped 302 if that helps. You will pick up about 100 Ft LBS of touque over the 302 for any given cam (302 and 351W can take the same cam with a change in firing order).
Stock:
289 CI=460LBS
302 CI=465LBS
351W CI=525LBS
Thank you, sir.
1979 Pinto LS1 76mm turbo project. th400 trans. 8.8 rear. 11inch 5 Lug on all four corners.  Hopefully it will be done spring 2009.
460Pinto
My 77 Wagon with lexan windows, full tube chasis, fiberglass front end and doors weighs 2585 without me. This thing needs to go on a diet. :hypno:
Stock:
289 CI=460LBS
302 CI=465LBS
351W CI=525LBS
LSXPINTO
Bone stock 79 with ac, spare tire, crap in back, full tank of gas, etc. 2,900lbs :amazed:
any idea what a 351 iron head long block weighs?
mrpinto
I had mine weighed at the track.
79 sedan, 302 w/ iron heads, C4 auto and 8" rear @ 2620lbs without my fat a$$.
He gave me the weight at all 4 corners also, but I don't have them in front of me right now. But I know it was considerably heavier on the front end.
1979 302 Pinto Custom
1971 460 Drag Pinto
My 72 with a 6 PT Bar was 2380 lbs
lencost
Quote from: map351 on September 07, 2008, 05:58:23 AM
Leonard
The firewall is moved back 3 1/2"
Thanks map351
Leonard
1975 Wagon 8" C4 2.8 V6
How much does a 1979 CW weigh?
map351
Quote from: Turbo Toy on September 07, 2008, 06:13:18 AM
My 80 with 2.3 turbo, T5, 8" rear with full interior all steel with no dieting and full of fuel. You can click on the image to enlarge it.
Helium filled tires.. :lol:
73 2.3Turbo Pinto
6S1941 / 289 Slab Side
Pinto FiberGlass
Turbo Toy
map351
Leonard
73 2.3Turbo Pinto
Pinto FiberGlass
lencost
Hay map351
Thats a car with 54.6% front weight.
I would be interested in seeing the front % of a V6 and a V8 compared to a 2.3 and 2.0.
Leonard
map351
2.3 Turbo T-5 9", Glass fenders.
73 2.3Turbo Pinto
Pinto FiberGlass
esoteric
What is the engine/trans combo for the 2368 weight?
Have you lghtened the car in any way?
map351
73 2.3Turbo Pinto
Pinto FiberGlass
My 80 Pony / 4 speed / 2300 / wet / weights 2375 lbs.
NoForKin
my 71 dragcar with after market block, lexan windows ,fibergalss front end ,hood,trunk,10 pt. roll cage  weights 2250 lbs with out me in it
                 Noforkin
....African or European?  :lol:
OK, if you are a Monty Python fan, you will understand my answer.
esoteric
What is the true weight of a '78 Pinto sedan?
Most publications specify 2500 or so, but I don't know if that includes fluids.
Thanks in advance
