1976 pinto for sale
Date: 01/12/2017 02:08 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
1980 pinto/bobcat floors
Date: 07/24/2018 08:11 pm
Date: 09/05/2018 06:30 pm
Date: 01/30/2017 01:48 pm
Pinto Wagon
Date: 05/25/2018 01:50 pm
Date: 03/05/2017 03:27 pm
Date: 02/25/2017 08:45 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
  • Online today: 452
  • Guests: 404
  • Total: 404
How do you shout?
Started by Ironman, September 01, 2008, 10:07:35 PM
dangerusdug
Thanks , but I shouted that out 3-days ago that I found the problem..
Scott Hamilton
Quote from: dangerusdug on September 01, 2008, 10:47:54 PM
Thats fine and dandy if that screen is working, it seems that you can only see it when your logged out..It appears that I'm missing the left side of the page when logged on but when I log out it's there ? very confusing :wow:
Up top, like Brad says.. "choose font size"  to the right you will see a L and a R with a plus (or minus) sign next to them....
This is where you add or remove the Left or Right frames of the site according to your preference... Play with these and see what happens..
Their a little different (one or the other missing [L or R] ) depending on where you are in the site,
This will fix it..
...and the point of the "shout" is? To get attention? I never knew what that box was for - didn't seem to make any sense, so I left it alone....
Another thing it might be is the computer viewing resolution.
I'm not the person to help if thats the issue but I have had that problem in the past.
Had to get a kid to fix it.
Best of Luck
FrankBoss
Try this. Up at the very very top of the page there is a box that says " chose font size" Make sure that it says " normal " in that box. if it does not, select " normal" maybe this is the problem????
dangerusdug
Quote from: Ironman on September 01, 2008, 10:07:35 PM
welllll?,...
Well, A deep hole in the ground from whence you draw water from.
Shout, a box under the words " Show last 10 " located on the left side of the screen.
Place your mouse arrow in the box and click. Then you will be able to type. After you are done with your message click on the box under that labeled " shout".
dangerusdug
Ironman
Ironman
