1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 07/08/2017 08:53 pm
Date: 03/23/2018 09:23 pm
Date: 01/06/2017 11:42 pm
71-73 Pinto Parts
Date: 06/06/2019 10:47 am
Date: 09/01/2017 11:58 am
Date: 07/10/2016 10:17 am
71-73 Rear valance panel
Date: 01/14/2021 06:54 pm
Date: 01/28/2019 05:15 pm
  • Guests: 2313
  • Total: 2313
need help for pinto 2.3 l engine modification
Started by ukport, August 29, 2008, 11:29:34 AM
mikerich1972
 I'm not real knowledgable on the kinds of modifications done to adapt these engines into industrial applications. However, I can offer some advice on the carbureation... DO NOT use the same carb!!
The carb that you found on the engine is most likely NOT ported for a usable secondary. What I mean by that is that the secondary barrel is probably not drilled for fuel, as this was used in a fixed-load situation.
I've run into this on another Pinto I had, where the secondary simply wasn't used, and had never been machined for it!!
1976 Pinto Wagon 2.3L
1972 Harley Davidson FLH 1200
1972 Pontiac Firebird 350/350
2003 Ford Motorhome
2018 Ford Focus
ukport
i have 88 model pinto engine which which removed from a jenerator. i want to use it in my car. i need help about modification; should i use carburetter or turbo kit.... if i use turbo kit, piston,should i change  crank, camshaft and oil pump.
note: this engine produced in brazil which for jenerators.
