Date: 04/13/2018 11:30 am
Date: 06/28/2019 09:14 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
pinto parts for sale
Date: 07/25/2018 04:51 pm
Date: 08/09/2018 11:09 am
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Date: 10/04/2019 08:43 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
  • Online today: 178
  • Guests: 162
  • Total: 162
1973 FORD Wagon
Started by delizious, August 28, 2008, 08:58:42 PM
Since the head bolts are somewhat recessed in the head, the torch method (although fun) would take part of the head with it.  You need a couple special 12 point bits to work on the 2.0L, 12mm for the head bolts and 8mm for the cambelt tensioner and oil pump bolts.  Lisle makes a bit set including these two, see link below for one source.
http://www.northernautoparts.com/ProductModelDetail.cfm?ProductModelId=8028
Delizious:
  While the torch method described above works, it only addresses part of your concerns  :P.
  Get yourself some Ford factory shop manuals; these show up on EBAY from time to time, and should be cheap. I got a full set of manuals (5 volumes) for my '76 Pinto off EBAY, and it cost me a whopping $9.99 + shipping - $16!!! These things have ALL the specs and data you need for everything mechanical, electrical, chassis related, lubrication, etc.
Quote from: delizious on August 29, 2008, 12:53:39 PM
Ok so its a 4cyl 2000cc ;D. So what about the firing order, timing, valve lash, torch for head bolts.
I think that the Harris acetylene torch would be good for the head bolts. Will cut them right off real good!  ;D
delizious
Ok so its a 4cyl 2000cc ;D. So what about the firing order, timing, valve lash, torch for head bolts, cam shaft? How do i get a hold of all that good stuff?! i wanna get dirty ;p
Lost 1972 Ford Pinto
Gained 1978 Ford Pinto
Lost Coz
The engine code will be the 5th character in the vehicle identification number...as follows assuming it is stock,
W  4 cylinder, 1600 cc engine
X    4 cylinder, 2000 cc engine
Y    4 cylinder, 2300 cc engine
Z   6 cylinder, 2800 cc engine
hope this makes sense  :)  The vin number is located on a tag inside the drivers door jam and also on a metal tag that is rivited to the dash on the drivers side...just look from the outside of the car, thru the drivers side of the windshield and the tag should be easily read from there. The vin will probably be on the title as well.
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
delizious
I'm having a problem with figuring out what kind of engine i have, i think i have it narrowed down to either 2.0 L EAO or 2.3 OHC. I must know before i take off the valve seal on the engine, every site i've gone to isn't specific from what i've gathered it was either made in Brazil or Germany. My friend said i might have some luck somehow looking up the VIN number, but how the hell am i supposed to do that? Oh yea what the hell does EAO stand for anyway??!!
