parting out 1975 & 80 pintos
Date: 08/24/2018 02:50 pm
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 01/24/2021 07:54 pm
Built 2.0
Date: 10/07/2018 05:27 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 06/07/2021 08:14 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 02/16/2019 10:46 am
Seeking parts
Date: 10/18/2020 10:35 am
  • Online today: 178
  • Guests: 73
  • Total: 73
Quiet Cooling Fan Wanted
Started by Late Models Best, August 28, 2008, 07:44:16 PM
Quote from: Late Models Best on August 28, 2008, 07:44:16 PM
My 79 CW with a 2.4 has the bigger noisey engine fan that they came with when equipt with AC.   The car is a 4 speed and and the fan makes a roar when above 2500 RPM.  I want to quiet it down allot.   The AC doesn't work so I don't need the extra air.  It has the fan shroud behind the radiator.   Should I try switching to the smaller non AC fan or is there a lighter flex fan that is quiet.   The only other thing might be a electric fan but how would I hook up a thermostat switch?   My other non AC Pintos don't make so much noise.  Any Help is Apreciated.
Tom D.
The non-a/c fan will fit if it is from the same engine. It will pull more air than an electric, and you won't need to worry about the t-stat failing to turn it on. An electric one would help give you better mileage and power.
BTW: 2.4?
Late Models Best
Tom D.
TJD
