Date: 02/27/2017 10:10 pm
Date: 02/28/2018 09:37 am
Date: 11/08/2019 10:01 am
Date: 08/09/2018 07:49 am
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
SEARCHING HOPELESSLY
Date: 02/02/2017 07:21 am
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
  • Online today: 178
  • Guests: 67
  • Total: 67
Quiet Cooling Fan Wanted
Started by Late Models Best, August 28, 2008, 07:44:16 PM
Quote from: Late Models Best on August 28, 2008, 07:44:16 PM
My 79 CW with a 2.4 has the bigger noisey engine fan that they came with when equipt with AC.   The car is a 4 speed and and the fan makes a roar when above 2500 RPM.  I want to quiet it down allot.   The AC doesn't work so I don't need the extra air.  It has the fan shroud behind the radiator.   Should I try switching to the smaller non AC fan or is there a lighter flex fan that is quiet.   The only other thing might be a electric fan but how would I hook up a thermostat switch?   My other non AC Pintos don't make so much noise.  Any Help is Apreciated.
Tom D.
The non-a/c fan will fit if it is from the same engine. It will pull more air than an electric, and you won't need to worry about the t-stat failing to turn it on. An electric one would help give you better mileage and power.
BTW: 2.4?
Late Models Best
Tom D.
TJD
