73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 08/05/2018 01:58 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 01/20/2018 07:51 pm
Date: 04/27/2018 10:28 pm
1980 Ford AM radio
Date: 12/22/2019 11:57 am
Date: 03/05/2017 03:27 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
  • Online today: 367
  • Users: 1
  • Guests: 199
  • Total: 200
  • rob289c
Got some work done on my 71 sedan today
Started by Reed, August 27, 2008, 09:47:42 PM
Reed
Actually, the floor pans were'n't that bad.  The rust in the trunk is all in the spare tire well.  he floor pans and cowl have already been repaired and POR-15-ed.  The work I am doing now is all dealing with the HVAC system and radio system (or lack thereof).
Quote from: Reed on October 25, 2008, 12:40:07 AM
Got the muffler done.  Found a few small rust holes in the trunk.  Due to the factory undercoating the rust is actually from the inside out.  I will deal with that later.
Yup, undercoating can actually hide issues. When I inspected my car, the silent but reasonably involved rust that was hiding between the carpet and floorpans was neatly concealed from beneath the car by the undercoating. It has long since been cleaned up and repaired with POR-15, but nonetheless I experienced the same thing.
Reed
Mostly I am replacing the seats and cleaning and fixing a bunch of stuff in the dash.  I need to get a can of the correct paint for the interior to deal with the surface rust too.  I will post pics when I get it all done.
Cool looking Pinto, Reed! I miss my 72. my interior took a week longer than I planned 5 years ago, and I've had the car for so long that I'm going back and redoing things I did before. Feels like I'm "rearranging the furniture"! Looking forward to seeing your interior when its done!
Reed
Now it is on to finishing up the interior.   :laugh:
Reed
I got the Pinto into the garage yesterday and put it up on jack stands.
I snuck out tonight and verified that the rear shocks are TOAST.  Totally dead.  After the shocks were removed the rear end bounced up and down nicely instead of sitting there like a rock.
I also cut a 16.5 inch section out of the muffler line and got about halfway done installing a little cherry bomb.  That should quiet it down some, hopefully.
This weekend I am hoping to finish installing the muffler and get the dash stuff taken care of (radio, heater/A-C, etc....).
Reed
Cool!  Thanks guys!  I will keep my eyes out for a Cimarron or a MarkVIII.
ive got mkviii seats in mine but had to make brackets to bolt to the factory seat rails. comfy though.
Reed,
I doubt if Eldorado seats would fit, but you might look for a junked Cimarron.  I had a 1987 and it actually had very nice leather seats with all the normal power adjustments.  If memory serves me correctly, there was no Cadillac emblem stitched into them or anything like that... should look great in a Pinto!
Reed
Well, both me and my Sister still live with our family, so I would still be able to drive the Pinto occasionally, and I would be in charge of maintenance.
Turn over to your sister? And then....another car for you? Or is that it for your Pinto involvement?
Reed
Hey you reminded me:
I also need to add sound deadening, repaint the black matel bits of my interior due to surface rust, repair/replace the headliner, and fix leaking front and rear window gaskets.
It is driveable, yes, but still needs a bunch of work before I turn it over to my sister.
Keep chipping away!  You will get it done.
Reed:
  You got me going, so I am thus compelled to share my "must do" list:
1) Finish the brakes
2) Replace the gas tank (has leaks)
3) Replace the windshield gasket
4) Fix the cowl leak hole
5) Rebuild the front end (everything is SHOT)
6) Remove and repaint/rebuild the dash
7) Get another solid steering wheel
8) Sound insulate the cabin and recarpet
9) New window sweeps
OKAY, I'm getting depressed......... :(. Sounds like you have "less" to do - at least you are driving and enjoying it. I am far from that....
Reed
Yah, its a bunch of little things.  I figure if I can get myself a free weekend of two full days where I don't have to work, I should be able to get most of the interior stuff done.  I am just going to gut the dash all at once.  Pull the glove box, heater stuff, stereo, etc... and replace it all in one fell swoop.  While the dash is torn apart I will hit the junkyard and try and find some nice black seats.  I would love to find something like a junked Eldorado with power leather sets   :afro:  but I am not sure if they would fit.  If I could find some seats with integral seatbelts I would love to ditch the stock shoulder belt.  I am glad I have it for safety, but I had forgotten how much i hate non-retractable belts.    >:(  If I leave it loose enough to adjust he radio it comes unclipped.  If I keep it tight enough so it stays fastened it rubs the side of my neck raw.   >:(    Maybe i will find something in a 80s era K-car, like a Lebaron or New Yorker.
These 15 inch Mustang rims are so wide that the tires rub the fenders in hard turns (such as parking).  The steering effort is too difficult so I am going to try and track down some skinnier rims and tires.  I am hoping to find something off of a Fairmont or some such at the boneyard.  Unless someone wants to trade me a set of the factory slotted mags...with tires.   8)
I think I can, I think I can, I think I can.....
Quote from: Reed on October 20, 2008, 03:15:41 PM
Brief update:
Not much more work done.  I got the rough idle and bad gas mileage ironed out though.  I set my base timing at 8 BTDC.  Factory spec is 6.  Plugs are gapped to .045 with the old Mallory Voltsmaster II coil and the pertronix ignition conversion.  The more I drive it the smoother the idle is getting.  I think I am burning carbon out of the cylinders with the leaned up mixture and improved ignition system.  I also think I might be cleaning rust and gunk off of the valve faces.
I topped up a few weeks ago and have driven roughly 50 miles since the total fill-up.  Just today my needle on the gas guage dropped to halfway between the "F" line and the first line on the guage. I figure I am getting roughly 30 MPG in city driving.  Not too shabby!
I need to pull the interior apart though.  These seats are worn out and hurt to sit in, I need to install a stereo and speakers that work, I need to replace my heater box and fresh air vents, I need to pull the rear seat and build a shelf to extand the trunk capacity, I need to install the dealer A/C unit under the dash, I neeed to install the A/C components under the hood, I need to install the front sway bar, I need to install the last front bumper guard after I replace the broken bolt in it, I need to track down the last few water leaks into the interior, I need to rebuild my windshield wiper linkage, I need to install a higher output alternator, I need to install the new cherry bomb muffler to supplement the rusted out turbo muffler already on the car, and I need to find me some skinnier rims and tires.  That should keep me busy this winter!
Sheesh, Reed:
  Your list sounds all too familar. I need to do about 100 things, too! If I could just get my brake system working, I'd be happy. Don't ask - nearly all of it has been replaced and I'm still trying to get a solid pedal. Man, it can be a lot of work!!
Reed
Brief update:
I just caught that, about the oven cleaner, I'll try anything once! (twice if I like it)  I don't think I can make the bumpers MUCH worse ( or can I ?)  so I'll try that.  Better take the plastic trim off the front bumper first, huh?
Quote from: Pintopower on October 07, 2008, 06:10:37 PM
Lookin good! The black top on the car really sets it appart from the others! Adding Pertronix is the best thing you can do! Every one I know with a 2.0 has it installed and they love it!
discolives78,
The ONLY way to polish out the aluminum bumpers is to take them off and FIRST get them deanodized. They will never polish out if you just try to polish over the anodized coating. It is very cheap to get them stripped. I spent about 30 bucks for 2 sets.
Pintopower, I saw on TV this weekend that oven cleaner will strip the anodizing off.  I believe it was on Trucks.  The guy had a piece of trim off an old Chevy pickup.  He used the oven cleaner to get the anodizing off and then he polished it.  I have not tried it yet to see how well it works but it may be worth a shot.
Pintopower
discolives78,
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
Reed
At last report I had disconnected the distributor vacuum retard hose going to the diaphragm.
I took the car for a long drive today and it felt slightly sluggish, like the timing was over-advancing.  I hooked the vacuum retard bacl up and the engine felt much better, but got a slightly rougher idle.  With the retard working the motor felt a little stronger and shifter smoother (?).
When time permits, I am going to spend some time with a vacuum pump and dial-back timing light and plot out the spark advance curve with and without the vacuum retard.
Reed
I only get to work on my Pinto when i can sneak away from work, so my motivation builds up all week long until I can finally take a couple hours off.
How is your wife's car doing?  If it is still idling rough you should see if your vibration dampener has slipped.  If it has, the timing mark will actually read more retarded than where the timing actually is set.  This will lead to poor idle which in turn leads to setting the idle speed screw higher than it needs to be and richening up the idle mixture more than it needs to be to get the idle smooth.
I tuned up my brother's van and found that his vibration dampener (on a 1983 Dodge slant six) had slipped 8 degree retarded.  I have taken his van from 3 MPG to 21 MPG (highway) by fine tuning the carb and timing.  The point is that timing is very important.  And the more I work on my 2.0 the more I discover that these are very finnicky carbs and engines that respond to minor changes.
apintonut
i need to get some of ur motivation!!!!!
i bout a sand blasting kit today and im going to try to get the scrap pinto off the trailer and the 74 on it sand blast and paint the engine compartment and set the turbo engine in.
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Reed
Snuck out tonight and spent some time tuning my Pinto.
Didf a compression check on the 2.0:
Cylinder 1: 125 pounds
Cylinder 2: 120 pounds
Cylinder 3: 120 pounds
Cylinder 4: 130 pounds
Not to bad for a cold dry compression check.
I have been fighting a rough idle and poor(er than I would like) fuel economy.    After I replaced the leaky valve cover gasket and did the compression check, I gapped the plugs back out to .045 and double checked the curb idle speed, mixture, and timing.
This time I disconnected both the vacuum advance line and the vacuum retard line (and plugged them both).    I then hooked up a vacuum guage to the intake manifold and checked the timing.   THe timing was right on at the factory recommended 6BTDC.   However, my intake vacuum was pretty low - only about 13 inches.
I tried setting the base timing to achieve maximum vacuum and managed to get the vacuum up to about 17 inches.  I then checked where the base timing was and saw that I was runnign at about 30 BTDC to get those 17 inches of vacuum. Howeverm the engine smoothed way out and I way able to lean out the mixture and back out the idle speed screw to get the motor to idle smoothly at the specified 650 RPM.
At this point I began to think that my viubration dampener had slipped and was no longer indicating the correct timing.   I didn't have time to check if the dampener had slipped, so I put the timing back to what currently reads to be about 16-18 BTDC.     Tomorrow I hope to go out with my positive stop tool and see if 0 on the timing tab is really TDC.
For now, the motor idles much smoother, much quieter, and I was able to lean up my curb idle.       I was getting 20-25 MPG in mixed driving before this tuning session, so I am anxious to see what kind of mileage I get now.     I am hoping that the wider plug gap, the advanced timing, the leaner idle mixture, and the disconnected distributor vacuum retard line will get my mileage closer to 30 MPG.  I am shooting for over 30 MPG and I think I can get there without adding and aerodynamic mods.
Next up will be getting the carpet to sit correctly, adding the chrome carpet hold-downs at the door openings, installing the new heater box I got, installing the new vents and vent controls I got, and then maybe even installing a tach and vacuum guage.
A pressing problem I discovered is that I have a leak from somewhere on the driver's side of the rear window.  There is a spot where the headliner has been pulled away from the window and underneath this spot a puddle forms and drips into the trunk.     No real rust yet, but I am worried that there might be some rust problems under the vinyl top.   :cheesy_n:
Otherwise the car runs and drives great!    But I do need to replace these worn out seats.    I need to find some nice leather power seats out of a late model import.
Updates and more pictures to come later as more work is done.
Quote from: discolives78 on September 29, 2008, 09:48:45 PM
At least the early bumpers can be polished out. the bumpers on the 78 are anodized alumunum  and get cloudy with age, anyone know how to take care of that?
even the most expensive carpet will not have holes for anything take it from me ive be in carpets and floors for 34 years you have to cut them
apintonut
have to try that, thanks for advice, I tried turtle wax chrome polish but that didn't help
Reed
Mother's metal polish?  All-Metal metal polish?
Reed
More work done lately:
Got the heater box back in. It is warped and worn out.  I need another.
Got the new carpet installed.  THe cheap eBay $105 carpet is okay.  Doesn't fit perfect, came in two pieces, didn't have holes for the seats, seatbelts, shifter or e-brake, but it is new and clean.
Replaced the widow felt weatherstripping on the two front doors.   This is more eBay items.   I used the "repop" brand.    Fit and look great, except the inner felts have one clip in the wrong place, so the very front-most clip doesn't go in its hole.    Doesn't really matter though.
Welded the broken track on my driver's seat and reinstalled the seats and lap belts.      First time I have had seats in the car for over a month!   It is much more comfortable to sit in now that the track is fixed.
Confirmed I need a new neutral start switch.     Trying to find a used one to avoid paying $100 for anew one. I need to ditvh the pushbutton in the dash and I want my reverse lights to work.
Replaced the (+) battery cable that was corroded by the arcing poushbutton wiring on the satarter relay.
More work to come.....
Quote from: Reed on August 29, 2008, 03:25:54 PM
No worries.  If it really bother me I will wrap a couple rags around my 7 inch c-clamp and straighten it out.  I was more worries about it being shiny than perfectly straight.      ;D
The Shiny police appriciates that...... :police:
