hood for a 79-80
Date: 11/30/2018 10:55 pm
1971-73 2.0 motor moiunts
Date: 05/17/2024 09:18 pm
Date: 03/07/2017 07:03 pm
Date: 06/12/2018 08:18 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
1971-1975 Pinto
Date: 01/09/2017 04:14 pm
Date: 09/09/2018 03:22 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
2.3 pinto carb
Date: 08/18/2018 02:07 pm
  • Online today: 123
  • Guests: 166
  • Total: 166
1972 Ford Pinto
Started by dcbchristian, August 23, 2008, 08:45:15 PM
Assuming you have a 2.0L engine, the stock fuel pump gasket is about 1/4" thick which could be considered a spacer.  I have not purchased a gasket lately and do not know what they are presently selling but if your gasket is thin, it may be a problem.
Sounds like a defective pump...
That or the arm wasn't installed underneath the aux cam lobe, and was installed on top of it, which in turn may have caused slight damage.
dcbchristian
cuz i just put a new fuel pump on and ran it. when i turned it off and tried to turn it on, it wouldnt start. i took the pump off and the spring and everything came apart. any suggestions?
beaner
my 72 2.0 has no spacer on it
dcbchristian
Is there a spacer on the fuel pump for a 72 Pinto?
