1978 RUNABOUT
Date: 04/01/2017 03:18 pm
Date: 03/06/2017 01:24 am
1973 Pangra
Date: 01/06/2015 02:19 pm
1980 Pinto Parts
Date: 08/05/2020 04:20 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 04/04/2020 09:38 am
Date: 01/12/2019 10:19 am
Date: 09/09/2018 03:22 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
  • Online today: 1,972
  • Guests: 1326
  • Total: 1326
Early Pinto Sway Bars
Started by TIGGER, August 23, 2008, 07:02:15 PM
ok my sway bar in the front is 1 and 1/8th from the mustang king cobra, but as far as i can tell you might be able to use one.
Which mouting points are you referring to?  The frame or at the control arms?
69GT
   My friend and I measured the difference a few weeks ago. Compared my 72 to his 75. The mounting points on the newer car were farther apart. I cant remember exactly but an inch or a little more. Mine came with no bar :(
I believe the one on my bobcat is the 1in swaybar. not 100% I can measure it out tmr when i have some free time
My stock '73 wagon front sway bar measures approx. .80+ (my eyes are too far gone to read an "old school" caliper very accurate). I assume it was intended to be 7/8" bar???
As to the second part of your question, sorry, I don't a '74 up car to compare it to.
Tom
Ironman
I know the thread was based on ability to make that conversion,.. I hope it works,.. it sounds like a nice inexpensive way to increase handling.
Ironman
Yes it is but I do not remember the size off the top of my head.  I believe it is a 1" or an 1 1/8" bar.
Ironman
Quote from: TIGGER on August 24, 2008, 03:11:51 AM
My 73 does not have a front sway bar but my 72 beater does.  I also have a wagon sway bar that came with a bunch of parts.  I will pull the one off the 72 for the 73 if it is different.  If not I plan on using the wagon bar.
Is the wagon bar thicker than the one that comes on runabouts and sedans?
Ironman
i used an Interpart 1 1/16" bar on the front of mine back in '71.  i don't think they are in business anymore.
try aadco (spelling?) or any of the high perf suspension companies that advertise in Car & Driver, Road & Track or Autoweek.  There are bound to be more than 1 outfits out there that may be able to help you out
try these guys with questions you may have.  they may be able to help:
http://www.stracing.com/alignment.html
Ironman
My 71 has a sway bar and a couple other peculiar things.
Ironman
Tigger your lucky..my 71 and 72 don't have front sway bars.
FrankBoss
Are the 71-73 Pinto front sway bars different than the 74 and up cars?  What about the brackets?  They look the same but without removing the front bar from my 72 I do not know for sure.  Has anyone swapped a later wagon bar onto an early car?
