Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 07/17/2018 09:49 pm
Date: 08/01/2018 01:17 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
free transmissions
Date: 11/28/2019 10:21 am
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
nos core support
Date: 01/03/2020 09:39 pm
1971 Pinto
Date: 03/04/2017 11:28 pm
  • Online today: 642
  • Guests: 548
  • Total: 548
Popbumper's '76 wagon - update
Started by popbumper, August 16, 2008, 08:59:52 PM
0 Members and 6 Guests are viewing this topic.
WINDSHIELD AREA - if you have been following, I had a hole in my cowl at the driver's windshield corner. This hole allowed water to enetr the cabin, creating rust on the floors. After treating/filling the hole, I needed to look at the windshield gasket as well, because I could see that the damage extended up beneath it.
In pulling the gasket, I found the gasket corner had been bent in towards the dash when installed at the factory, creating a pocket for rainwater to collect in. THis water created some additional problems at the pinchwelds between the cowl and pillar structure. I cleaned these areas up, puttied them, and treated all with POR-15 in preparation for a new gasket, and window trim clips.
Pic 1 - windshield removed
Pic 2 - Wire wheeling at the pinch weld
Pic 3 - perimeter treated with POR-15
Update for July 11th 2209
Been over a year now since I picked up the car. Progress is slow at this time of year because, well, it's really HOT out, and like a lot of folks, I don't have storage space or a garage to work in, so the weather is a dictating factor.
WHERE I have had time and the weather has cooperated, I have been involving myself in at least a few areas, including the windshield, dash, and front end bumper area. MUCH remains - I am starting to understand my limitations from financial, time and skill levels, and I believe that my "directive" is changing - more on that later.
Without further adieu, these following pics show shots of the windshield work and dashboard effort. Stay tuned for an article in PINTO TIMES - I have captured the entire process in pictures and will write a feature about the windshield stuff; here's a small snapshot of the effort.
And the pictures are.......................
:lol:
Have new pics of progress, just need to go through the arduous task of resizing them before posting. Lots of progress stuff to report on. Thanks for pushing me, Rob!  :P
78txpony
Well..........  :P
The audience awaits in silence........  :o
-Rob Young
1997 H-D Sportster
I like your definition of TGIF!!
And just think... that cowl will never rust there again!  :tgif: Thank Goodness It's Fixed! ;D
powderblue76
Pop,
I'll chime in a give you a giant ATTABOY for your meticulous and thorough detail on both the car and in the documentation.
I have that same annoying leak, and "someday" may be sooner than I thought, thanks to your post.
As an avid welder and fabber, I can't fault you one bit for the cowl fix.
Due to your needing to learn to weld, buy the welder and "stuff", practice...etc....that fix will last forever, and that is what counts.
Another (right) way to get it done, I like that.
POR15 is the future for me, the Pinto, the '66 Fairlane and the '39 Chevy.
Keep the posts coming, even for the lurkers like me.
I have read many a cowl post and never really understood the problem area. Now I do and where to look. Might just be the cause of my floorpan repair area.
Thanks!!!
Excellent job Chris! That cowl and inner fender look better than new. Shame no one will be able to see it after you put the fender back on!  :amazed: Thanks for the pics, I know there are a lot of leaky cowls out there, other members will benefit from seeing how you repaired it. Looks good from my end!  ;)
Hey Pop, Just invite him to the pool! :evil: :lol:
No problem, I suppose that particular subject was a sore spot, and the word "skimp" didn't quite hit me right. Thanks for the good words. Some days this restoration gets the best of me.
289pinto
Wow, no need to get all defensive. I simply seemed liked everything else was looking so good that it didn't meet the standards of the rest of the vehicle. Didn't mean to offend you!
1978 Pinto wagon, 289, 8" rear, 17" cobra R rims
Skimp? Well, let's put it this way. Some guys have the knowledge, facilities, tools, and experiece to weld. I do not. I waited nearly a year to fix this hole, suffering over how to do it right, and finally got tired of sponging rain out of my car and did something about it.
I'm busting my butt to restore this as far as I can without putting it on a rotisserie, or spending $15K. Rather than trying to learn to weld, finding somebody who could, and making the requisite noise in my driveway, I took three hours, fixed it for a few dollars, did it myself, and sealed it adequately.
Given all the time and effort I have put into the car (and what it still needs), I won't suffer over something that's a hassle to fix, and I'm not sorry I did it this way. I wish I could have welded it, but what someone else expects is not always what I can do. As long as my own standards are met, that is what's important.
289pinto
Looking good! you seem to be doing a real good job but why would you skimp and fill a rust hole with fiberglass instead of doing it right and welding a patch in it on your cowl?
Quote from: hellfirejim on June 11, 2009, 07:15:26 AM
 I choose to do the mechanical first.  Actually I really didn't choose i had no choice...  :rolleye:  When it is completed then I plan to tackle the body and interior work.
Thanks Jim. I am doing mechanical at first as well, with a little bit of "misc" thrown in as it presents itself. Wanna make it bulletproof underneath (full chassis rebuild/restore), then motor/eng compartment, then interior, then body (if at all - I may keep it original just for kicks). I agree it's tedious and expensive, but worth it.
Man you have got that thing looking sweet. I am a believer in that por 15 its good stuff.
Keep up the good work little at a time. That way you can enjoy it longer.
Chris,
Hang in there on posting.  On my thread I rarely get a post from other people but the views are over 10,000 so somebody is watching.
Take some solace in that you are doing it right.  That is what I am doing to the best of my ability.  I choose to do the mechanical first.  Actually I really didn't choose i had no choice...  :rolleye:  When it is completed then I plan to tackle the body and interior work.
I too have found out the process is taking at least twice what i thought and about twice as exspensive but now i am hooked on as it is refered to as that damn little car. :lol:
Remember we are watching...
Just imagine what it will look like DONE  ;D.
Man, this is a LONG process but I must do everything right...
Get some POR-15. If you don't soon, you're going to see a can show up at your doorstep. All I need is an address.....
I HAVE TO GET SOME OF THAT POR-15!!!
I am jealous that your car looks so good and it ain't even finished!
Second up? Inner fender (wheel side) restoration
Having completed the suspension restore/rebuild, I needed to address the ailing inner fender surfaces (those hidden by the fender), including the cowl drains, the edge where the fender meets the inner lip, and beneath the plastic insert.
Pic 1: Exposed inner fender, showing the clean suspension but incomplete/old undercoating, and rusty vent tube/surfaces around the drains
Pic 2: In process - here the painting has begun (POR-15), after surface rust has been exposed and addressed with a wire wheel.
Pic 3: "Complete" - you can see where I have >not< yet added the POR-15 putty to the cowl patch. Once complete and sanded, everything got another coat of POR-15. Even the inside of the cowl was thoroughly cleaned, and a POR-15 "dauber" was used to coat the inner cowl. No more rust, and water flows easily. Also note the complete refreshening of the undercoating, the "restoration" of the gas tank vent tube, and the removal of the old charcoal canister.
First up? COWL HOLE. This bugger really has annoyed me for a year, why I did not fix it first is beyond me; I guess I let it overwhelm me when I got the car.
PROBLEM: EVERY time it rained (meaning, ALL WINTER AND SPRING), I had to sponge off my floor pans, which would collect up to an inch of water.
1st pic: The hole, close up, after wire wheeling. Where this hole is presented an unusual challenge for welding, so I went the "soft repair" route.
2nd pic: Two layers of POR-15 fiberglass were laid up over the hole and allowed to dry. NOT SHOWN: Aftre it dried, I covered the entire area with POR-15 PUTTY, and sanded everyhing smooth, creating a rock hard barrier.
3rd pic: The completed repair. IT RAINED HARD TONITE AND THERE WAS ZERO WATER IN THE CAR AFTERWARDS. Hooray!!
Update for 6/10/09
Been almost a year since I bought my car. While it seems like there still is a LOT to do, I have also accomplished much. Floors are solid, entire brake system is new, gas tank is repaired/restored/lined, front suspension has been completely stripped out and restored, interior has been stripped, all rear bumper hardware has been sandblasted and painted, front bumper hardware is removed in readiness for restoration, some interior panels have been restored, dash pad has been restored, and rally wheels have been obtained and restored.
Replacement dash and power brake booster have also been purchased.
Wow! Still busy at it, though as the days get hotter, the work slows.
On tap for tonite? Front end restoration (non-suspension) and cowl leak fix. See next posts.
Thanks guys, it means a lot. I hope it's worth the effort, tere will be a LOT more before all is said and done.
I know all the guys and gals appricate you as much as I do. Your pict-history is going to help me while I resto-mod my car since I have to start all over again. Your posts have inspared me to do every little detail part the right way, and make it look good too!!!
Keep up the good work and I hope mine will look and fuction as good as yours.
Popbumper,
Keep posting the progress even though i do not respond i do keep up and  as of right now  my car does not need any major work it is nice to have the info avable when and if i ever need it.
78txpony
Quote from: popbumper on May 12, 2009, 12:55:15 PM
What's next, Rob? Retrofit of factory A/C  :hypno:?
It sounds like you want that A/C box again...   :-\
Do they make medicine for these types of disorders??  ;)
-Rob Young
1997 H-D Sportster
I'm at home for lunch right now, heading back to work. Of course, when I got here, I took her for a quick ride. It's SO great to be "up and running" again.
78txpony
I am glad i was able to come help out a little bit.  If it wasn't for the date I had that night, i would have stuck around to see the car move under its own power!
Attention to detail takes a LONG time - my Olds has taught me that.  Freshen up one area, and everything else looks like s*** on a white rabbit...  :reek:
I wish i repainted my front end components when i rebuilt it back in 2002, but I guess it will have to wait until the next time...  I never thought I would try to restore the car. To me, it is still just a cool-weather daily driver...
I have to say those AFTER pics look great, and it was not because of the photographer!   :smile:
:police: The city gal will be impressed - you know she will want a ride!   :lol:
I am glad that big accomplishment is done - now you can move on to the next!  :drunk:
-Rob Young
1997 H-D Sportster
