78 pinto wagon
Date: 03/03/2020 01:07 pm
Date: 07/13/2018 02:21 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 04/28/2018 04:12 pm
Wanted 1973 Ford right fender
Date: 06/03/2017 08:50 pm
Date: 02/05/2020 11:06 am
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
Date: 09/22/2020 11:33 pm
Date: 02/10/2017 09:30 am
  • Total Topics: 16,268
  • Online today: 192
  • Guests: 120
  • Total: 120
I think I got a lemon, any ideas?
Started by Kid Colt II, August 07, 2008, 07:02:52 PM
You need to find out IF it is the valves or the rings.
Did they put a little oil in each to see if it brought up the numbers?
You also need to understand that IF it IS the valves and you have the head re-done, there is a good chance (50-50) that the rings will start to leak at least a little.
Again, it all depends on your goals for the car, and the OVERALL condition of it.
Kid Colt II
Quote from: apintonut on August 07, 2008, 07:12:03 PM
these car were designed  to run on leaded gas so u ether put in substitute or have the head gone though its about 3-400$. it is much easier to just have the harden seats and valve done than it is to stayed stocked up on lead substitute, and as u are there now. its just the price u pay to play.
Sorry, I'm a newbie so I don't understand. Are you saying that the car is running poorly because I am using normal unleaded gasoline?
Also, getting the valves fixed would only be $300-$400?
1972 Pinto 2 door sedan 4 Speed, 2.0 I4 ohc engine
IT all depends on YOUR goals.
If the car is STRAIT and SOLID, an engine job is cheaper to work with. Might be worth putting the money into (DEPENDING ON YOUR GOALS) but without seeing the car in person....
If the car sat for a long time, it might be ok after it runs for a while. Yamaha marie sells a good additive to free stuck rings. The stuff works great.
You can also learn as you go.
Where are you located?
apintonut
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
Kid Colt II
I just bought a 1972 4-speed Sedan exactly one week ago. The owner told me it drove ok and had no major problems. I however do not know how to drive manual, but I was willing to learn. I bought the car and had a friend drive it home for me. It was having major trouble going up any hill and the engine would die constantly, so I didn't get a chance to practice driving once the car got home. As soon as my friend that drove it home was available again, he drove it to the shop for me. I had a Tune up done, and they said my problem was the carburetor. We took it to a carburetor shop to have the carb rebuilt, and the guy said it had valve problems. He didn't recommend that I get it fixed, but said that I should try to get my money back since the seller lied to me about the mechanical condition of the car. I really like the car itself, but I am not mechanically inclined myself, so I have to pay to have mechanics do the work.
He tested the compression and it was showing:
Cylinder #1   145
Cylinder #2   25 - Very Low
Cylinder #3   70 - Low
Cylinder #4   55 - Very Low
Will this cost more than the car is worth to fix? Should I try to return the car?
Been a really stressful day.
