1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
76 Pinto Wagon
Date: 07/08/2020 05:44 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 08/30/2021 03:20 pm
Date: 04/10/2017 07:30 pm
Date: 10/05/2017 02:26 pm
Date: 10/04/2019 08:43 pm
  • Online today: 489
  • Guests: 372
  • Total: 372
8.8 rear swap
Started by dholvrsn, August 03, 2008, 12:32:24 PM
with the 8.8 and t5 i had to have the driveshaft shortened 1 inch. retaining the matching flange on the 8.8 and the drive shaft.
1975 pinto
What would be the driveshaft length be for a 2.3/T-5 with a 8.8 rear??? Is it the same as an 8" rear?
      -Robert
6 miles south of Dayton, Oh
the Disc set for the late model mustangs that have them will not clear 14's.  I have the conversion started on mine and cant put the calipers on it as of yet till I get either 15's or what i Ultimately want 16's.
1975 pinto
Would I be better off getting one out of a fox since I want a little wider rear so I can run a little more backspace?
Then with a 8.8 how is the driveshaft length affected compared to a 8"?
Little off topic, but would be a good disk brake for the 8.8" rear (to clear 14" wheels)?
      -Robert
Turbo Toy
Quote from: 77turbopinto on August 04, 2008, 07:50:30 PM
Then why do the axle shafts have different part numbers left to right?
Bill, it's because the lengths are different from right to left going to the splines in the carrier.
turbo74pinto
Quote from: 77turbopinto on August 04, 2008, 05:34:49 AM
IIRC: Doesn't the Ranger rear have the meatball off to one side to clear the gas tank?
yes, check the pics below.  this rear was taken out of a mid 90s 2wd (if i remember right) 4.0 ranger. later fx4 models could be had with a torsen locker, 31 spline, and 4.10s.
http://i307.photobucket.com/albums/nn294/ford371/P1090007.jpg
bob
grats on the find. and the score
apintonut
scored a 8.8 out of a 94 explorer for better than free as i sold a buch of the rest of the vehical but it was not the one i was hopping for but the price was right but the code was 41 and i was looking for d2
http://www.explorerforum.com/ntrprize/Axle.htm
74 hatch soon to be turbo 2.3
73 sedan soon to be painted
stiletto parts(4 sale)
79 pinto wagon & beentoad
I am workin on getting  8.8 posse my self. Will be taking it to the Axle shop to have it trimmed down for a better fitment and to have the perches re-welded into the locationes needed for the bobcat.
pintopaul2003
i have an 8.8 out of a mustang gt in my 80 sedan, i cut the brackets off and welded new spring pads on . they are so close to the 7.5 in size. also the axle shafts are differant in lenght..
we have a new addition to the pinto family
Hunter Daniel born nov 21 2006  5lbs 12.2 oz                     pintopaul@verizon.net
tbucketjack
The ranger is the way to go. I'm replacing capri rear end with a 90 ranger 7.5 rear with a 3:45 ratio. Wasn't lucky enough to score a 8.8
woodie
I have an 8.8 from a fox body mustang under my 75 wagon looks good think its 2" wider something like 54" have to do some cutting and welding though hope this helps woodie
watch this
apintonut
if it is cant be more than a inch i was going to pull the rear out of my ranger and put in a pinto 8" but the truck sold before i got to it. i had the rear out of my shed and sitting behind it it all looked REALLY close other than the saddle. the pumpkin looked to be right on.
Quote from: apintonut on August 04, 2008, 06:24:15 PM
nope
apintonut
nope
apintonut
its been a bit but the ranger was 1" shorter or 1/2 shorter
Have the measurements on that?
apintonut
I'm starting to get frustrated with the lack of available 8" parts these days. So are there any 8.8" rears that are close in width to the lovely Pinto?
DGH
