Date: 03/06/2017 01:19 am
Date: 01/04/2017 04:07 am
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Pinto Watch
Date: 06/22/2019 07:16 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
KYB shocks
Date: 02/08/2017 07:09 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Electrical
Date: 03/29/2017 11:37 am
Date: 08/27/2018 11:11 am
  • Online today: 1,292
  • Users: 1
  • Guests: 379
  • Total: 380
  • warhead2
Water temp? 79 very basic car with 2.3L
Started by russosborne, August 01, 2008, 03:41:15 AM
bigbellybob
i have a NOS energy drink bottle for my over flow. cut the hose on an angel and run it to the bottom of the bottle and it will recirculated. super cheep and easy it just zip tied on
gordie
Check the condition of your radiator cap too.  That is a cheap fix that I just used to cure a similar problem.
The "engine" light comes on for low oil pressure and/or high coolant temp.
Yes, it will spit out coolant if it is over filled. If it does it over and over, check the level. If you do not see coolant in the top tank over the tops of the tubes, the coolant is low.
Maybe I am an idiot. But I can't figure out what light on the dash would tell me if the car is overheating. Would it just fall under the "Engine" light? I only have four lights that come on when I start the car, and there is no temp or hot type light.
Reason I am asking is that it has been spitting up a bit after I get to work (35 mile drive). I believe it is just because I may have overfilled the radiator and there isn't an overflow bottle yet. But I am concerned
I hope to go to gauges eventually, but that won't be for a while.
I really think I need to come up with an owner's manual for this car.  :lost:
Thanks,
