Date: 06/19/2018 03:58 pm
Date: 03/25/2019 09:02 pm
74 hood
Date: 07/03/2017 03:46 pm
Date: 02/10/2017 09:30 am
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
Date: 04/10/2017 07:30 pm
Date: 01/28/2021 03:49 pm
Date: 08/02/2019 04:18 pm
  • Online today: 314
  • Guests: 324
  • Total: 324
headliner install
Started by wedge446, July 31, 2008, 05:19:16 PM
Like your choice of words...
"keep the car hotter than hell"...
In Texas, at least right now, that wouldn't be hard. Been between 101 and 105 every day for the last 12 days or so.
 A word of wisdom keep the car hotter than hell ,,,,,after you got it hung on the wires use a blow dryer on low and put heat under the liner and dont melt it be careful,keep the dryer moving back and forth,best to have a friend here,, ,,,,then glue and pull it tight with no wrinkles,,while its hot and not too tight ,,,,, about 40 percent,,of its pull hot,,,and use a plastic putty knife with the corners rounded so they dont poke through the material to tuck it in.... there`s that floor layer word again......tuck it........................ ha ha ha ha !!!!
wedge446
Thanks, I`ll try ace...
On my 75 wagon the windshield had to be removed( i was doing it anyways) The headliner is wrapped around where the windshield gasket goes.. Its also was glued in place..
On a wagon, must the windshield be removed in order to change out the headliner? I have heard this rumor is TRUE....
wedge446
Got a model name and number for that? All the ones I`m finding takes staples that are too long.
wedge446
I`m installing a new headliner in my wagon and can`t find any staples that they use for the sides...
Anyone know where I can find some or is there something different I can use?
