Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 01/24/2021 07:54 pm
New cam
Date: 01/23/2017 05:11 pm
71,72 Pinto Door Panels
Date: 06/17/2018 08:27 pm
Date: 09/05/2018 06:30 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 07/08/2022 11:51 pm
Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
  • Online today: 2,670
  • Guests: 586
  • Total: 586
Installing a temp and oil gauge (where do they go?)
Started by pinto4sho, April 10, 2008, 02:49:59 AM
 :welcome: pinto4sho,
The oil sending unit is near the back of the block on the drivers side. Under the intake manifold.
The temp sending unit is near the back of the block on the pass. side. Under the exhaust manifold.
Goes in the same place as the factory sender. The kit will have different size brass fittings, just take out the stock sender and use the matching fitting from the kit. Make sure to use teflon tape on the threads.
pinto4sho
I own a 73 runabout with a 2.0 motor and it doesnt have a temp or oil gauge. I wanted to know where i would go about installing a temperature gauge and oil gauge?  Where do they connect onto the motor?
1973 pinto (gets me from A to B)
