Date: 10/31/2018 12:04 pm
Date: 09/19/2019 04:43 pm
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
McLeod Clutch
Date: 04/12/2017 12:08 pm
Date: 02/16/2019 10:46 am
Looking for front seats
Date: 08/10/2021 09:54 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
  • Online today: 452
  • Guests: 400
  • Total: 400
wheels
Started by herrrmrrr, April 04, 2008, 03:52:11 AM
bobscat
That first set you have a link for, I used to have on my car.  Also, I would think that if the first set I KNOW fit, than the other ones made by the same people should.  As long as they are 4 x 4.25 bolt pattern, they will work.  However, be sure to check the back spacing and make sure they will clear.  If you don't know how to do that, there is usually an instruction article on summit or jegs website to explain it.  It is pretty simple.  As for aluminum rims, however, sometimes you have to watch on 13" or even 14" to be sure that they don't rub the calipers.  (They tend to be thicker than steelies, and sometimes even have different "steps" inside the rim, especially reverse mount wheels.)
