2.3 turbo intake (lower)
Date: 07/15/2020 09:29 pm
Date: 07/08/2022 11:51 pm
Seeking parts
Date: 10/18/2020 10:35 am
Date: 06/18/2018 03:47 pm
Date: 08/02/2019 04:18 pm
Date: 09/19/2019 04:43 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
Date: 04/25/2017 12:17 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
  • Online today: 548
  • Guests: 467
  • Total: 467
Highway rear end recommendation?
Started by hoots, March 29, 2004, 06:43:45 PM
rbohm
 8)a 3.00 gear will have your pinto crusing at 75 and turning 3k rpm. since the car is light, and the 302 makes good torque a 3.00 gear is all you need for what you want.
64 falcon
66 mustang
82 fairmont
a man's fate is a man's fate
and life is but an illusion
fordsix.com admin
vbmdu
for comparison, I was taching out at 3000 rpm at 70mph with 185/70-13 tires and a 2:73 rear.
straw boss
I think 3.00 gears in the 8'" rear will have you running about 3300 rpm at 75 with a stock converter.  Since you already have a 302, and are not interested in blazing acceleration, you would probably be happier with something around 2.73.
I based my rpm estimate on my car's old combination.  I ran 2300 at 55 with 3.00 gears, 4 speed, and about the same size tires you have.  That works out to about 3140 at 75, and figure about 200 more rpm for converter slippage.
By the way, what do you have in the rear now?  Must be around 3.73.
a truck! ;D   3:08 to 3:25 or so should work for you and still give you a bit of decent acceleration, go into 2:something , its gonna really feel like a dog off the line.
hoots
Just finished...(OK, it'll never be finished) with a V8 swap, 302/C4. Took a ride down the highway, still have the original rearend, and my rpm's were 3k at 55mph. Looking for a 8" posi that will let me do 75-80mph at 3k. The rear wheels are 15x7 with 225/60/15 tires. I want a highway cruiser for pulling my bike to ralleys, not dragracer. What do recommend?
