FLOOR PANS
Date: 06/12/2020 07:24 pm
Date: 10/10/2019 09:42 pm
Parts for 74 Squire Wagon
Date: 09/16/2019 07:35 pm
1979 pinto
Date: 04/19/2018 02:02 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Date: 10/10/2019 10:02 pm
Date: 07/17/2018 09:22 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 02/28/2018 09:37 am
  • Online today: 131
  • Guests: 113
  • Total: 113
oil tube
Started by 80bobcat, October 04, 2007, 12:57:11 PM
80bobcat
Ok thanks..I`ll have to rig something up as a bracket..and I may JB Weld it in place..I`ll see when I rig it how secure it is the motor isn`t in yet..
Look Officer..it`s a Pinto would YOU stop short?
When I build fresh blocks, I use JB Weld to secure the tube.
Not sure U could get a block clean enough to do this while still in the car????
The oil tube is a friction fit.  It should have a tab that is supposed to bolt to the intake manifold to keep it in the block.  I would make it removeable as possible as you never know when stuff will happen.
80bobcat
Hi all....the oil tube.. does it have an O ring where it goes into the block? or is it friction fit? It`s an `80 Bobcat  with an `87 merkur motor I`ve done the swap with the plugs.. rear for front...now the tube sits very loose.
If it is friction fit ..anybody have any ideas? I was thinking of JB weld or along those lines
all input is welcome.and TIA
PS: I`m hoping to get the turbo project back on but things are going slow
