Date: 03/14/2020 01:52 pm
Date: 12/09/2018 11:35 pm
Date: 01/21/2023 04:19 pm
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Pinto drive train
Date: 06/29/2018 08:32 am
1976 Ford Pinto Pony
Date: 09/06/2018 05:40 pm
Date: 09/21/2018 11:35 am
Date: 04/12/2017 08:15 am
1980 Pinto w/ Trunk
Date: 08/10/2022 04:09 pm
  • Online today: 2,612
  • Guests: 2548
  • Total: 2548
LA3 LB3 questions?
Started by 2point3turbo, June 07, 2007, 05:05:12 PM
2point3turbo
turbowagonman
I have a Manual Brake 80 Pinto 4 spd. Pedal Assembly I'm willing to sell.
I didn't install the Boost Switch in either of my projects.
turbowagonman
2point3turbo
Thats what I was thinking but had to ask. I am going to be switching to T5 eventually but I need to get the parts from a Merkur stick to do the swap. So if anyone has these parts please email me. I have the T5 I just need clutch pedal and cable and what ever else is needed. By the way... is the Boo switch really needed?
turbowagonman
I think the LB3 is the Auto Computer and the LA3 is the Stick Computer. If that's the case the LA3 doesn't hook into the tranny. If you have a C-3 it doesn't hook into the tranny either. Right????
So if you have the LA3 it doesn't matter if you have an OLD C-3.
turbowagonman
i think the only difference is in the controls for the overdrive auto that was used in the tc. im not positive , but the difference in the factory rated power came from the T fitting on the compressor of the turbo that worked the wastegate.it had a different size opening to regulate the boost to 10 lbs. the timing curve should be the same on the 2 computers.
2point3turbo
I have a C3 auto and put in the LA3 but want to know if I should run the LB3 instead?
