Date: 01/06/2017 11:42 pm
Date: 01/24/2021 07:54 pm
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
71-73 sway bar
Date: 06/12/2021 10:12 am
1976 Pinto runabout
Date: 03/28/2017 08:14 pm
1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 05/13/2021 05:33 pm
1972 Pinto for sale
Date: 05/19/2021 12:41 am
  • Online today: 178
  • Guests: 163
  • Total: 163
Sputtering, turbo going out?
Started by 2point3turbo, January 23, 2007, 04:08:05 PM
2point3turbo
It just so happened to be that I bottomed out right after I started it up at a Schucks store so it may have just happened when I started it up just moments before. However it ended up being the fuel pressure regulator. I traded it out for an extra I had with brown top injectors and tadahhh!!! It runs great now, just like it did before but now its idling high. I have the timing set at 16 btdc and my tester went out for the TPS. I will get another and put that at 96v or is there a better setup then this?
I thought this started after you bottomed out?
2point3turbo
I dont have any  way to test fuel pressure but I do have an extra regulator to try out. I also wonder if I might be a tooth out on timing. I dont have a timing cover notch, that part was broken.
What do you have for fuel pressure?
2point3turbo
I want to ask if my timing could still be the problem. It runs fine and I tested the turbo and its boosting 15psi. When I drive it down the road and when it starts to boost it sounds like backfiring sort of.  Not like a real backfire but like its being muffled. It runs good otherwise. Just cant seem to figure it out. I am putting the new turbo on come tuesday but I want to know what else to do. It has all new sensors on it so I dont see that as the problem. I also wondered if it may be fuel related.
I don't have much experience with a fuel injected 2.3T but I can tell you that pulling the codes would help out a lot.  The code scanner for that car should cost under $40.  It may save you a lot of time and money.  There is no way I would have been able to fix my Ranger without one.  Autozone should be able to scan it for free if you don't want to buy one?
2point3turbo
I have changed the knock sensor and did not fix the problem. I had the timing a bit off but still seems choked or almost like not enough air. I do however still have to hook up the O2 sensor but I have just been to lazy to retrace the wire and hook it up, could that be my problem? I will get it back on and see.
2point3turbo
Yes I have inspected everything and cant seem to find any problems. I did however take a trip in my Uncles Ranger with the 2.3 and his does the same sputtering when you hit the gas. Whatever is wrong with his car is wrong with mine. We are going to change out the knock sensors and then go from there.
did you get down and look at the pipe?
2point3turbo
I dont have any way of pulling codes. I am going out of town today and will check all connections and change any and all bad sensors then buy new turbo. How can I get the codes off if the ECU is not hooked up to a light or panel? What wires would I jumper to get the codes? Thanks.
Metered air systems don't like intake leaks, are all the intake tubes/hoses/clamps still in place and tight?
The sensor that would take the worst "hit" with what happened would be the O2, check that too.
Are all you other sensor connectors still plugged in?
Codes??
BTW: Codes??
2point3turbo
What air ducts? I will replace the knock sensor just in case. I have over half tank and have had it lower and no problem. It just started at the very moment I curbed the downpipe and thats why I think something to do with the turbo. It was getting weaker and weaker and now as soon as it tries to get boost it will sputter. Hopefully just a sensor. I have replaced the head so all ducts or piping have been reattached.
CHEAPRACER
Are you using the stock fuel tank and pickup? If so, my '74 won't pull on less then quarter tank without it doing the same thing. It drove me crazy for awhile until I filled the tank back up.
Codes?
Is it building any boost?
Did you knock the air ducts loose?
Bad knock sensor?
2point3turbo
My car is now sputtering and somewhat backfiring when on the gas just at the time of boost. It was running good when  all of a sudden I bottomed out on a curb just barely and hit my downpipe. Since that moment it has been doing this. I originally thought it was a head gasket the way it was running but I swapped heads and still the same problem. I have not had a turbo go out yet but I am sure its about time. Does this sound like a turbo problem? I had a gauge on it with boost controller and at max even with the controller it was only pushing 15psi. It used to do better but has slowly got worse and now this sputtering only under boost has got me wondering. Let me know what you guys think. I have been wanting to upgrade my turbo anyway!
