Date: 12/31/2017 09:03 pm
Date: 07/20/2017 01:23 am
Date: 09/01/2017 07:52 am
78 wagon instrument y
Date: 04/30/2018 07:41 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 10/26/2020 03:24 pm
Date: 04/15/2017 05:14 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
  • Online today: 447
  • Guests: 206
  • Total: 206
windsheilds
Started by pintoman, January 01, 2007, 04:47:36 PM
krazi
I was gonna say that.  :cheesy_p: oh well, I think you deserve a one up!
krazi
Quote from: Cookieboy on January 11, 2007, 08:38:56 PM
you can get windshield gaskets/seal for the 71-78 models at http://www.autokrafters.com/ but you will have to call ( 1-800-228-7346 ) as they do not list all the Pinto stuff on the web site. I have bought most of the door/windows/hatch seals for my project from them.
yeah, I'm Krazi!
They are out of the windshield gaskets right now (1/11/2007) but I just ordered 1 today and 10-14 day backorder and it should be shipped.
pintoman
I called a local glass company about this question.They told me that if the build date is July of 78 and up ,the Pintos all used the same windshield.Plus they said that the windshield seal was no longer offered.If i find out anymore i will let you all know.
Thanks for setting me straight ;D
Actually the 79-80 glass is bigger.
You can install any windshield into any Pinto IF you use the correct method of installation.
1971-78 MUST be set using the rubber seal and the 79-80 MUST be installed with the Caulk-Strip.
My friend supposedly installed a brand new 79 80 windshield in his 72 hatchback about 10 years ago.  The windshield was a little smaller than the original one out of the 72 but that is all that was supposedly different.  We figured it was smaller due to the fact the 79-80 windshields are glued in where the 78 and earlier use the gasket.  He said he had to put extra sealer in the gasket to make up for the difference but it seemed to fit and seal otherwise?  However, it was kinda hard to tell as the cowl was rusted out on that car.
billnall
No the 79-80 Pinto has a different glass and the opening has a different design.
Ford Parts Man
pintoman
Do all year and model Pinto's use the same size windshield?If so can a windshield be installed in early model Pinto's like the 79 and 80 models.If so the windshield seal may not be needed on the early cars.
