79-80 full glass hatch
Date: 01/04/2017 04:04 am
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
McLeod Clutch
Date: 04/12/2017 12:08 pm
1977 Pinto Cruizin Wagon
Date: 08/07/2023 02:52 pm
Date: 05/24/2020 08:19 am
Date: 08/27/2018 11:11 am
Date: 03/29/2019 07:20 am
I need a 1976 hood
Date: 12/19/2016 06:02 pm
Date: 09/05/2018 06:30 pm
  • Total Topics: 16,268
  • Online today: 160
  • Guests: 102
  • Total: 102
Ignition Coil
Started by oldman, January 06, 2007, 01:27:13 AM
The tower arcing over to the nearest ground seems to indicate an open high voltage circuit.  If you still have the old wires, try them again (first the wire from the coil to the distributor).  I have installed new wires that turned out to be bad.  Also make sure the distributor rotor was installed (unlikely but I have forgoten this).
oldman
Have a 79  pinto 2.8l, coil went nuts changed it out and all the plug wires, went to start it and no go discovered the tower on the coil is arcking over to the + and - leads on the coil, changed coil still same issue, used the electric grease and 8mm wires any ideas on what is wrong ??? or how to fix it :hypno:
