Pinto brake booster needed
Date: 05/08/2021 09:00 am
Date: 12/04/2018 07:40 pm
Parting out 77 Bobcat Hatch
Date: 11/06/2017 04:16 pm
pintos for sale
Date: 12/11/2018 04:29 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Date: 02/05/2020 11:06 am
Date: 01/28/2021 03:49 pm
Wheels and Parts
Date: 07/06/2018 04:50 pm
Date: 08/27/2018 11:11 am
  • Total Topics: 16,268
  • Online today: 160
  • Guests: 111
  • Total: 111
repair remote mirrors
Started by Cookieboy, January 03, 2007, 11:18:33 PM
Sorry, I have been out of the office most of the day.
I sent a reply to your email, and yes, that is perfect.
I also mentioned that both sides would be great if you can, but if if is too late now I understand.
Thanks again,
Bill, sent you email and pictures at your aol address, let me know asap.
Tigger, I got the passenger remote handle removed and what you suggested w/tapping it might just work  ;D
Bill, is this the part you want? and if I cut at the lines will that be what you want?
Hey Cookie,
   In the second pic, at the bottom, almost centered is the corner end part of the rad. support that is spot welded on. If you are getting rid of the car (junking it), would you be able to cut it off and send it to me (not at the welds, just hack it off around it)?
I was tearing the 80 down last night, have to get rid of it asap. I wasn't gonna keep the motor but have decided I better just in case I need parts. I'll get that passenger side remote handle out today and check it out.
I just went and unscrewed a passenger side knob from one of my spares.  It looks like it is an 8-32 thread.  You may get away with tapping the hole with an 8-32 tap and be able to screw in the knob.  The passenger side knob is a little longer but it should work.
Thanks for the picture.  I looked and do not have a spare drivers knob.  I have two or three spare housings and plenty of passenger side knobs and housings.  Take a close look at your pass side knob.  It most likely unscrews.  You may be able to thread it in to the drivers side?  I will let you know if I run across any in the future.
Tigger, here's a picture of the cable for the passenger remote mirror with the fender removed.
Tigger, I never got out to the garage tonight to remove the knob for the passenger side to see if it would work. I did look at it and it does look different and I wonder if it will work considering it's setup w/4 wires unlike the driver which has 3. I'll have to do the final disassembly to see exactly how it works.
Pintony told me the easiest way to get access to drill the holes for the passenger mirror is to remove the fender. Looking at how the wire runs on the 80 parts car I can see why.
Cookie boy it is still hard to tell but it looks like you need a new knob.  The Macro for close up pictures on most camera's is the flower.  Let me look and see if I have one.  I am not sure if I will make it to the wrecking yard this weekend.  The forcast calls for rain.
Out of all the mirrors I have fixed only one had a loose or stretched cable.  I did not fix it, I just swapped out the guts from a Granada mirror.  After, thinking about it some, you should be able take the slop out by moving the crimps on the ends of the wires.  These crimps fit inside the knob.  I am not sure how easy this would be?  Another thought would be to put in a taller spring behind the adjuster knob.
I installed sport mirrors on my 73 a few months ago.  I got the parts off a 73 parts car that I had last year.  The drivers side was easy.  Since the door was rusted and crushed on the parts car, I cut the knob hole out, making it a template.  I just traced the hole out and drilled and filed it to the correct shape.  For now, I chose to install the non remote passenger side mirror from my parts car.  The glass is tight so I am not too worried about it.  I have a nice remote mirror for it as well but I have not looked to see what it would take to drill the holes for the cable.  When it comes time to paint the car, I will have to decide what I want to do.  I am worried that the non remote mirror will loosen and become useless.
ADaughen, I looked for the setting you suggested and no can find... cheap camera I guess.
dholvrsn, after looking at all the controls on the 2 I have from a 1980 I would say there is no adjustment. Keep in mind that for the passenger side mirror there are 4 cables and driver side has 3. Each of these cables has a thin wire that runs thru the middle and no matter the quality after 26+ years wires will stretch causing them to be loose. This would be the main reason I don't really want the mirrors to be the remote style on my car but I want the sport look they have. I ordered a set of generic sport mirrors today to see how they would look compaired to the factory mirrors. In the picture they looked good but will make up my mind after holding them in my hand.
Since we're on the subject.... Is there anyway to adjust them for that they hold their settings instead of drooping down after every time that I slam the door?
Hey Adaughen, I'll try that tonight, Thanks  :)
ADaughen
If you want good closeups set your camera to Macro and get one of those cheap collapsable tripods.  ;)
The pictures aren't too bad...
'78 Cruisin' Wagon
I goofed... same pic twice.
Hey Tigger, I will take the passenger cable out tonight to check and see if possible to use for the driver side. I have a passenger side mirror but cable is cut and I think I can make it a non-remote so it could still be used. It would be just for looks so functionality isn't a major concern. And with that in mind if I could find a passenger side sport without remote tight glass is a non-issue. I have the chrome (both sides) from the 80 w/notch for the mirror but it looks a little different than the chrome for the 73. Not sure if it will work until I remove and compair mounting to the chrome for the 73. Pintony had told me that the early sport mirror for the passenger side was not remote so I knew that.
Personally I don't care if I have remote mirrors on either side. I do want the sport type but really don't want them to be remote and if I could somehow convert the 2 remotes I have to manual I would do it. I will not mount a remote mirror on the passenger side, I don't want to cut holes and run the cable. If I can repair the driver remote I would cut the holes and mount it up.
I have looked at some of the generic sport mirrors and just don't want to mount up cheepo plastic mirrors on the pinto. It may come to that but for now I want to see what I can do with what I have.
I attached a couple pics of the knob for the driver remote so you could see what it looks like. sorry for the poor quality, my 4.0mp camera doesn't take good closeups w/flash.
I have not tried heat yet but that may be a good idea.  Lately most of the mirrors I have fixed have had the crimps pretty tight where both halves are together.  If this is the case, I have been using a utility knife to carve a grove between the two halves, wide enough for a thin blade screw driver.  Once I get the blade to fit, I gently work both sides apart.  It will take some time to get them apart to get the cable out.  I typically use needle nose pliars to grab the cables to yank on them when I feel I have them apart enough.  Sometimes they come out. Sometimes I need to spread them apart more.  Most of the time they will be stuck in a little.  Make note of where each cable goes and how far the cable was in the housing before you yank them out.  The cables need to be the same distance into the housing as they were before you took them apart or there will be slop causing the mirror to vibrate.  Also each cable was painted a different color.  Green, yellow, and red, although most are faded by now.  If you look closely on the knob housing, there will be a R Y and G stamped in it telling you which cable goes where.  However since most of the cables are faded by now it sometimes is hard to tell what color each cable is so I would mark them before you remove them just to be on the safe side.  Unfortunately, the knobs on the passenger side are different than the drivers side.  I am not sure if they interchange as I have not tried it.
I wish I would have known that you needed this stuff before I sent off your window.  I would have looked thru my mirror parts to see if I have any knobs left.  I went thru quite a few this year and need to go to the wrecking yards and replentish my stock.  I may be going this weekend, as my buddy told me of a wagon in one of the local wrecking yards.  He will check it out for me tomorrow.  If it sounds promising, I will probably go over the weekend and pick it clean ;D
The early pass side sport mirrors were not remote.  You had to roll the window down and adjust them by hand.  I have found it hard to find good used early pass side sport mirror.  Most of them have loose glass from years of use.  I have not found a good way to tighten them up.  The remote ones are usually tight since the cables keep them in place.
I take it you are looking for a remote passenger side mirror?  Do you have the pass side door chrome piece that has the notch for the mirror?
Tigger! you are the man! mine looks like it was a one piece. I looked at the housing and can see how it comes apart. It does look tricky and easy to break. What is the best way to uncrimp the housing? Would heating up the metal a bit help to keep from breaking it or do you think that would make it brittle? I'm not talking a blow torch or anything.. perhaps with just a lighter for a bit-o-heat without over doing it.
I do have a passenger side remote and the cable is useless on it (it's been cut and mirror removed) but I now know where to get the replacement for the driver side knob  ;D
Many Thanks
I have fixed dozens of them.  I can't tell if yours is broken or if the knob part that screws in is missing?  For some reason, I have seen different adjuster knobs, some with the screw in knob and others that are one piece.  I usually replace the knobs with some spares that I have aquired from other mirrors that were damaged. The trick is uncrimp the cables from the aluminum housing without busting the housing.  You will need the housing intact in order for the cables to be recrimped so the remote works properly.  I do break them sometimes so be careful.  I hope this helps some.  Do you have a remote pass side mirror or a manual one?
OK... here's a good one.
Is there any way to repair the adjusting handle on a remote mirror? It's missing...
see pic
