Date: 08/08/2018 12:26 pm
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
78 fender and hood
Date: 03/23/2021 01:07 pm
Date: 04/25/2017 12:17 pm
Date: 01/12/2019 10:19 am
Date: 01/28/2017 12:30 pm
SVO SWAP
Date: 03/15/2018 03:12 am
FLOOR PANS
Date: 06/12/2020 07:24 pm
  • Online today: 529
  • Guests: 504
  • Total: 504
FMU question... Yes or No?
Started by 2point3turbo, January 12, 2007, 12:27:25 AM
Gaslight
An FUM goes on the return line back to the tank.  Not the pressure side.  It is basically used to back the fuel back into the cylinders by closing up the return to the tank.  I have used them to make 165cc injectors flow as much as 300cc injectors.  But it does not beat properley sized injectors.  It can also be used to compensate mechanically for an ECU that does not understand boost.  Say adding a turbo to a NA car with an NA ECU.
Jake
2point3turbo
If an FMU is used to increase pressure when in higher boost range then wouldnt it suffice to just get bigger injectors? I have 35lb injectors and want to know where my money is best spent?
