74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 10/28/2018 08:45 am
Date: 07/30/2018 04:32 pm
Date: 04/21/2017 02:03 pm
Pinto drive train
Date: 06/29/2018 08:32 am
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 11/02/2019 10:25 am
  • Online today: 500
  • Guests: 489
  • Total: 489
frame info needed.
Started by pintocrazy, January 18, 2004, 10:12:21 PM
71pintok
I put in custom frame connectors from the leaf spings to the motor sits they kook like this  <  on one side and this  > on the other.
pintocrazy
i want it to take whatever my foot gives it.  and don't want to have to worry about the frame when it's run hard or i get wild with it. i like to trun up the juice and see what shakes alose.
what are chevys. cracked heads every valve rattles oil leaks everytime.
hoots
I used MustangII (74-78) V8 mounts. Almost a perfect fit. Don't worry about the frame unless your gonna circle track race or run it down the strip every weekend.
pintocrazy
thank you very much for the info. what motor mounts did he use if ya don't mind me asking  thanks again.
Underdog76
As long as you have compatable motor mounts, you don't need to change the frame at all. You will probably need to cut out the radiator support and relocate the radiator in front. You may also need to cut some holes for headers in the compartment walls. at least that is what was done to my dads 302. As a side note with a sideloader four speed we had to turn the trany mount around backwards, and cut holes in the brackets for the shift rods. But that shouldn't  be the case with your pinto.
Fast as lightning, strong as thunder
pintocrazy
ok not to sound dumb. i need someone who can give me the info i need on.  puting a va 302 in a pinto what frame work does and don't need to be done. this will be done on a 1975. would like to also hook a c4 automatic transmtion to it.  anyone who would be nice enuff to email me the complete info on this i would really thank you.
