Date: 02/21/2017 06:29 am
Date: 07/20/2018 03:00 pm
Date: 06/18/2018 03:47 pm
Date: 12/09/2018 11:35 pm
Date: 09/17/2024 12:35 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 03/25/2019 09:02 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
76 drivers fender
Date: 07/20/2018 08:24 pm
  • Online today: 367
  • Guests: 296
  • Total: 296
speedo cable
Started by dusty, February 21, 2006, 03:00:44 PM
Quote from: CHEAPRACER on March 03, 2006, 11:44:25 PM
I know this has came up before but why is this? Mine worked perfect once I removed the electronic speed sensor and used the stock 4 speed insert.
I do not think the Pinto came with a speed sensor.
The cable wasnt long enough on my 79 wagon with the 4 speed to 88 t-bird t-5 swap.
I'll check the 78 wagon with V6 and auto.
CHEAPRACER
I'm also using the '88 turbo coupe trans & stock '74 cable. I also used the t-5 speedo gear installed on the 4 speed insert to match the turbo coupes 3:55 gears which I also used in my 8 inch, things just worked out too perfect.  ;D
Hello turbo toy,
I'm using the mustang trans.
I wonder if that is the difference????
turbo toy
Pintony,My Pinto is a 1980 sedan that originally came with a four speed.My T5 is out of my 88 Turbo Coupe.I have a 76 Pinto parts car that I can check the length of the speedo cable.Would be interesting to see what year they may have changed the length of them.
CHEAPRACER  &  turbo toy,
Must be running the tranny from a Merkur. ;D
Maybe the late Pinto  had a longer cable.
Lets hear more about this...
turbo toy
Yeah,mine too.Bolted right in with no problems and works great.
CHEAPRACER
Quote from: Pintony on February 21, 2006, 09:35:06 PM
Pinto speedo cable will not work with T-5.
dusty
so would one work if it came off a c-3 trans.let me know thanks agin dusty.
Looks like I will be saying ouch too. I cut it when I gutted the car.
Thanks,
Hello Bill the cable from the donor car will work perfectly.
Unfortunatly I ruined mine and I just bought 1 from ford.
I told them a 87 mustang 2.3 T5 W/O cruze control
About 80 bones...OUCH
Hello Dusty,
Yes any Pinto speedo cable should work with the C4 or 4speed hummer tranny.
dusty
i have a 80 sedan with a 8" rearend 2.3 motor and c-4 trans.can you use any speedo cable off a pinto.thanks dusty
