Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
79 pinto driveshaft
Date: 08/18/2018 02:03 pm
Date: 04/07/2021 06:12 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Date: 03/25/2019 09:02 pm
Date: 11/29/2018 10:26 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
door sills
Date: 03/14/2020 03:20 pm
1975 mercury bobcat
Date: 08/14/2018 03:40 pm
  • Online today: 531
  • Guests: 412
  • Total: 412
1973 Front End Parts, No Problem!
Started by Lickety Split, October 02, 2005, 02:45:42 PM
72Wagon
 How hard of a job was it? Did that mean you also had to use a later steering rack? Any other changes were needed?
Kevin
1972 Wagon
Quote from: pintoguy76 on November 15, 2005, 11:28:08 AM
What about just putting a 74+ suspension under the 73...would the control arms and rack bolt up to the 73?
On my 73 Pinto I cut the complete 74-UP cross member out and welded into the 73 chasis
Sorry to inform you that the 1973 Pinto will not like the parts you have purchased for the 74up MII.
They are not the correct geomerty for the 73.
Keep us posted as to how these parts work on your 73 MAYBE we can learn something???
Lickety Split
I am a new guy here, butt not to Pinto's. I got into rebuilding the front end of my 73 Pinto only to find that the frontend can't be found at the everyday auto parts store!
