hood for a 79-80
Date: 11/30/2018 10:55 pm
Date: 08/26/2018 06:23 pm
Need seals Pinto Wagon
Date: 02/16/2017 05:09 pm
Date: 05/22/2018 02:27 pm
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
Date: 02/28/2018 09:33 am
Date: 08/01/2023 06:53 pm
Date: 11/02/2019 10:25 am
Date: 01/24/2017 12:36 pm
  • Online today: 125
  • Guests: 127
  • Total: 127
Wagon Rear Shocks
Started by flash041, October 03, 2018, 09:40:20 PM
Great information.
I used regular (sedan) Pinto shocks on my wagon. Because the threaded portion is so long I was able to slide a thick wall tube over it. Ironically the early Pinto's have a similar pin type mount on the shock top as on the bottom, not the crossbar type in your picture. Lacking additional thick wall tubing I then stacked extra cupped washers on the top end to place the shock closer to its "travel range." So, either way the thick wall tubing, or stacked washers, you get the same results because the spacing places the shock very near its normal operating position. I was able to compensate for 1-1/2" of the 2" difference in the shocks. Note I did this to the "inside" sections.  6+ years and so far so good. But I do caution that one does this "at their own risk."
flash041
I was in need of new rear shocks for my 78 wagon. As you may know they are not available any more. I tried to find something close, with the same mountings. I found late 70's Camaro's rear shocks have the same mounts, but about 2 1/2 inches longer. I measured about 7 inches to the axle bump stop with suspension at rest hanging. The shocks have 8.25 inches of travel. the original shocks are about an inch short whit suspension at rest. So by my calculations the shock should bottom out about the same time as the bump stop. When installing them I attached the bottom first, then used a ratchet strap to pull and compress the shock into place. The part number for the coil-overs in Monroe #58551.
