Date: 01/23/2017 07:41 am
Rally spoiler wanted
Date: 05/04/2017 01:32 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
Date: 04/20/2017 10:10 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Date: 07/10/2016 10:17 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
pinto for sale
Date: 09/11/2016 09:47 pm
Date: 03/16/2017 10:00 pm
  • Online today: 1,166
  • Guests: 1091
  • Total: 1091
Vacuum advance
Started by 1974pintowagon!, July 17, 2017, 07:21:22 AM
Think of it this way. Holley would not put the port outlet on the carbs unless it was the way to go. Don't fight it unless you have no vacuum port to use. If manifold vacuum is all you have, try it.
justplainwill72
All mine have been ported....but I prefer the mallory yl....kinda expensive but setup correctly and it's killer
Go to http://www.mortec.com/carbtip1.htm  for a very good site on Holley carbs. These people know Holleys.
dennisofaz
The difference between ported and manifold vacuum is:
Ported vacuum is low at idle (closed throttle), and full vacuum at open throttle.
Manifold vacuum is high at closed throttle, and low at open throttle.
Dennis
Go to the Holley web site to find out. They tell it all better than I can.
pintofarm
Could either of you please explain IN DETAIL how they operate differently than I stated above?
The Whistler
Sorry to tell you port and direct vacuum do not operate the same at any point! Most Fords use Port vacuum! That includes all Pinto!
Turbo is a way of life
pintofarm
Only at idle is there a difference.  Both sources operate exactly the same off idle. So hook it to whatever source that provides the idle that you like.
rob289c
My Mustang is hooked to a ported source.  I believe manifold vacuum would be at full advance all the time.
rob289c
1974pintowagon!
Where is best on a stock 2.3 to hook up the vacuum advance? Manifold or ported vacuum? Where is yours hooked up?
